New Topic New Reply
Author: Subject: front wings
whitstella
posted on 17/8/11 at 05:16 PM Reply With Quote
front wings
hi
thinking about fitting my front cycle wings so just a couple of questions.
1. whats the best way of fixing them to the brackets?????
2. which is the corret position????? how far back over the wheel if you know what i mean.
cheers steve
stevegough
posted on 17/8/11 at 05:29 PM Reply With Quote
Question 1: fit them with gunge - I used 'Tigerseal'.
Question 2: see the drawing in the IVA manual - it is self - explanatory.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
martynrich67
posted on 17/8/11 at 09:34 PM Reply With Quote
Let me know if they wobble about a lot, coz mine do.
Myke 2463
posted on 17/8/11 at 10:15 PM Reply With Quote
Wing position
The manual shows the wing just forward of the front of the rim, i thought that someone posted that the wing must be at least forward of the tyre, right / wrong ?
Be Lucky Mike.
stevegough
posted on 18/8/11 at 08:25 AM Reply With Quote
er, wrong. The front of the wing must be just in front of the rim (as stated above) and the back edge needs to come just below the centreline of the wheel.
And to answer Martin who was rich in'67's question; no, mine don't wobble at all - even at 120 mph. Let me see if I can find a piccy of the gungy stuff fitment...yes - not very clear, because after fitting the stays, I also used some of Car Builder Solution's um, solution called 'Wunderseal' on them.
Also - to help illustrate the wing fixing position for Whitstella and Myke 2463 - here's a profile pic of mine...
Luego Locost C20XE.
sprouts-car
posted on 18/8/11 at 08:39 AM Reply With Quote
So is this right?
Build blog
stevegough
posted on 18/8/11 at 08:45 AM Reply With Quote
Originally posted by sprouts-car
So is this right?
Perfect illustration.
Luego Locost C20XE.
sprouts-car
posted on 18/8/11 at 08:58 AM Reply With Quote
So is this right?
Is there any logical reason for that amount of coverage?
Ie the back is to stop stones being thrown up (not that I think it would stop that)
Build blog
eddie99
posted on 18/8/11 at 10:29 AM Reply With Quote
As above on position and i also used some tiger seal type stuff and was perfect, survived 110mph at north weald with no noticeable movement at all.
Pezza
posted on 18/8/11 at 04:37 PM Reply With Quote
From the IVA manual
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
sprouts-car
posted on 19/8/11 at 04:09 PM Reply With Quote
So my diagram is wrong (I was just trying to clarify what had previously been said in the thread.
I assume the IVA answer is the correct one?
Build blog
martynrich67
posted on 21/8/11 at 04:31 PM Reply With Quote
Mine snapped again today - same bracket different place.
I think it needs a new bit of flat bar - maybe it's fatigued.
Ah well, caliper and wishbone off again tomorrow to allow repairs!
StevenB
posted on 29/8/11 at 10:13 PM Reply With Quote
There was a thread ages ago saying the forward measurement
was a vertical line off the wheel rim but that would change
depending on the wheel size whereas the 30deg forward will
always be in the same position.
S
handyandy
posted on 29/8/11 at 11:50 PM Reply With Quote
I was having a similar discussion after posting photos of my finished car when someone commented that my cycle wings wouldn,t pass the IVA requirements, so I copied all the measurements as stated in the IVA manual onto a perspex sheet & placed it against my wheels to check my wings.
Below is a pic of how it translates & you can see that my wings will pass the IVA test.
Hope this pic helps, it also depends on the individual shape/style of the cycle wing in relation to what position of the wing will pass/fail
cheers
andy
[Edited on 29/8/11 by handyandy]
New Topic New Reply
