Author: Subject: protech spring spec?
bassett
posted on 18/8/11 at 03:33 PM Reply With Quote
Hi, i hae an MNR Vortx inbound, can any owners help with spring spec ie length,dia etc as im going to order some softer ones from db faukner
cheers
Johneturbo
posted on 18/8/11 at 04:20 PM Reply With Quote
I've got 175lb on the back same length and dia as standard ones
and on the front i'd go with 150lb same length and dia as standard
[Edited on 18/8/11 by Johneturbo]
bassett
posted on 22/8/11 at 07:57 PM Reply With Quote
Hi John, yeah thats what i was going for. Dont suppose you know the front/rear spring lengths along with the internal diameter?
Adam
lucy
posted on 23/8/11 at 10:40 PM Reply With Quote
spring length
Got mine from Protech who were most helpful and very reasonably priced.
If you measure the open length of the shocker (centre of eye to eye) they will give you the correct length of spring. I think it's 5in shorter than shocker ( not 6in as were on my rears).
My poundage is similar to previous reply and now seems more comfortable whilst managing to cope on the track. Standard springs would probably be better for the track.
Eatpies99
posted on 24/8/11 at 11:08 AM Reply With Quote
what lb rating are the standard springs Lucy?
Johneturbo
posted on 1/9/11 at 03:42 PM Reply With Quote
soz Adam i missed your reply, i'll have to pop in the garage as i still have the standard springs. so 1.9 dia and i think the lengths. i think were 8" front 9" rear
i'll confirm tomorrow, unless someone else does first!
