Author: Subject: air filter ?
nick-york
posted on 19/8/11 at 10:18 PM Reply With Quote
air filter ?
I am building a ron champion with 1600 crossflow and weber 32dfm carb fitted but not sure what type of air filter i need !Whatever i use will probably stick out above the bonnet because i prefer that to a bonnet bulge . so can anybody recommend me a filter ? If it sticks out above the bonnet it would need to be waterproof in case i got caught out in a shower . thanks - nick
austin man
posted on 19/8/11 at 10:39 PM Reply With Quote
shouldnt be a problem if it rains I have run Twin 40's with K+Ns and bike carbs with foam filter stuck out of the bonnet with no problems
snapper
posted on 20/8/11 at 06:30 AM Reply With Quote
A bit of water helps, having a torrent fill the carb while parked won't.
Basically if your moving or running the engine a bit of rain is fine.
Something like a piper cross with foam top is probably best for good airflow.
There is an adaptor that fits on the carb and allows you to duct air from a nosecone filter.
I eat to survive
I drink to forget
