New Topic New Reply
Author: Subject: Peugeot 13" Alloy Wheels
whitestu
posted on 25/8/11 at 07:39 PM Reply With Quote
Anyone got any idea if Peugeot 13" alloys will fit over Sierra front disks / rear drums?
They are factory fit ones, not aftermarket.
Stu
CRAIGR
Contributor
Posts 2755
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 25/8/11 at 07:58 PM Reply With Quote
Long time since i've seen any 13" peugeot rims most were 14's and 15's
[Edited on 25/8/11 by CRAIGR]
ssc28
posted on 25/8/11 at 08:09 PM Reply With Quote
The steel 13" peugeot ones do fit sierras with front discs and rear drums, I've used them as they were quite strong.
big_wasa
posted on 25/8/11 at 08:13 PM Reply With Quote
The factory 13" pug alloys will not clear vented sierra calipers they are a 108mm pcd put the spigot is a little larger so will not be centered by the spigot. They often have flat seated studs and not the 60 deg nuts used by ford. to top it of they have an offset of around 18mm unlike the sierra's 38mm so they will stick out an extra 20mm for a rim of the same width.
[Edited on 25/8/11 by big_wasa]
whitestu
posted on 26/8/11 at 07:39 AM Reply With Quote
Thanks guys
New Topic New Reply
