Author: Subject: Fuel pressure reg
beaver34
posted on 30/8/11 at 06:00 PM Reply With Quote
Fuel pressure reg
Hi all,
Does a turbo motor need a fuel pressure reg that rises with boost pressure, or can I just use my normal 3 bar one?
imp paul
posted on 30/8/11 at 07:06 PM Reply With Quote
yep you can use a rising rate reg it would be fine for the job it is down to your set up locost way is this lol http://www.racetep.com/begireg.html
[Edited on 30/8/11 by imp paul]
Antnicuk
posted on 30/8/11 at 08:02 PM Reply With Quote
yes, you need a rising rate FPR with a boost source connected to it.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
mark chandler
posted on 30/8/11 at 08:10 PM Reply With Quote
It depends how much boost you are running, if only a 8psi then no need to worry as long as you can flow enough fuel for full power.
If you are pushing large amounts of boos then the effective fuel pressure drops by the boosted pressure so you need to compensate.
Its worth measuring the fuel pressure anyway as this will be a reference of the regulator goes wrong in the future.
Point to note is that if you retain standard injectors then you can compensate by adding extra fuel pressure when under boost.
Regards Mark
[Edited on 30/8/11 by mark chandler]
matt_gsxr
posted on 30/8/11 at 09:18 PM Reply With Quote
I'm a bit confused by the question.
If this is EFI then don't most normal fuel pressure regulators are manifold referenced aren't they? So the pressure will rise with the boost pressure.
Or is the question about a "rising rate" fuel pressure regulator. In this case the fuel pressure increases with boost pressure but actually MORE than the increase in boost pressure.
It depends on the install and whether you have enough fuel flow. Also do you have the ability to map, or are you relying on the extra fuel pressure to supply the extra fuel. You probably know all this though.
Matt
beaver34
posted on 30/8/11 at 09:19 PM Reply With Quote
can you not just map more fuel in under boost? or is it just easier for the mapper to do it with rising rate?
matt_gsxr
posted on 30/8/11 at 09:38 PM Reply With Quote
You can definitely just map around it, and it works fine. You can do this with a manifold pressure referenced regulator, or even if you don't connect up the reference (as long as you aren't running too much boost, as Mark Chandler says).
A rise rate regulator does have an advantage. It comes down to fuel injector sizing, as you can get away with smaller fuel injectors if the pressure is high (when you need the fuel), the benefit of small injectors is that you can get a better idle (which can be a problem with massive injectors).
Matt
beaver34
posted on 30/8/11 at 09:42 PM Reply With Quote
thank, i do have a reg ill post a pic tomorrow it has vac port on the top, ill be running at least 12.5 psi thats what springs in the external wastgate, its either a 3 or 3.5 bar reg that i used to run my n/a engine on will be running astra vxr injectors which i believe to be around 440cc
