Author: Subject: another petition - MOT 4-2-2
speedyxjs
posted on 12/9/11 at 12:21 PM Reply With Quote
Another petition this time against the idea to make MOT's after 4 years from new and then every 2 years thereafter rather than the 3-1-1 we have at the moment.
[Edited on 12-9-11 by speedyxjs]
MikeCapon
posted on 12/9/11 at 12:29 PM Reply With Quote
Why? What's the problem with 4-2-2?
speedyxjs
posted on 12/9/11 at 12:35 PM Reply With Quote
Quite a few cars seem to be failing MOT's on their first MOT as alot of new cars nowadays are used as company vehicles and rack up pretty high miles in 3 years so by 4 years could be pretty dangerous. I would like to know what others in the trade experience to see if its just me!
r1_pete
posted on 12/9/11 at 12:49 PM Reply With Quote
Add to that the number of people buying cheap old cars which have just scraped through an MOT, and treating them as disposable after a year, they would then have 2 years to deteriorate before being 'forced' off the road or repaired.
UncleFista
posted on 12/9/11 at 12:53 PM Reply With Quote
Have a look at this website and tell me the average car owner should drive their car for 2 years before having it looked at by a mechanically minded person.
I think most posters on here forget how little most people know about their cars, the cars on that site are "driven" in to the garage..
example;
Tony Bond / UncleFista
CRAIGR
Contributor
Posts 2759
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 12/9/11 at 01:50 PM Reply With Quote
No doubt it will be signed by the owner of every mot station in the land.
coyoteboy
posted on 12/9/11 at 03:15 PM Reply With Quote
I'm all for keeping 3-1-1, while it's expensive and frustrating for me who maintains cars well, for every me there's 20 someone elses who don't know their arse from their elbow and never look at the car or get it serviced. I've seen dozens of cars with bald tyres, cars that pull drastically on hard braking - all sorts that I can spot just driving down the road, let alone with a set of ramps and an inspection lamp.
pmc_3
posted on 12/9/11 at 03:22 PM Reply With Quote
By the time the car i've got at the moment was 4 years old it had covered 120k miles!
posted on 12/9/11 at 03:45 PM Reply With Quote
My understanding it is not going to be 4-2-2 which I actually think would be a very good thing what we are likely to get is a much stricter version of the current 3-1-1 systemie the worst of both worlds.
coyoteboy
posted on 12/9/11 at 03:51 PM Reply With Quote
Why do you think 4-2-2 is a good thing?
Ninehigh
posted on 12/9/11 at 04:12 PM Reply With Quote
example;
Is that a brake disc?
AndyRead
posted on 12/9/11 at 04:17 PM Reply With Quote
As above why 4-2-2?
Not only is 3-1-1 better for the safety of the driver & all other road users,
It is also hard enough for MOT stations to make a good living without halving the car turnover!
Macbeast
posted on 12/9/11 at 04:36 PM Reply With Quote
Let's say I scrape through the MOT with tyres that are just within limits. Are they going to be legal / safe after two more years ?
London minicabs have to do MOT every six months.
Benzine
posted on 12/9/11 at 04:54 PM Reply With Quote
is it half of what used to be a vented brake disk?
iank
posted on 12/9/11 at 05:35 PM Reply With Quote
Originally posted by AndyRead
As above why 4-2-2?
When they introduced that in Canada (maybe just in BC) they doubled the price of their MOT equivalent to deal with that 'problem' - so anyone wanting 4-2-2 because of the apparent cost advantage might want to think about that.
[Edited on 12/9/11 by iank]
Anonymous
posted on 12/9/11 at 05:51 PM Reply With Quote
Example;
What's wrong with that! Plenty of meat left on it... and there are 3 other ones as well!
It's Evolution Baby!
jollygreengiant
posted on 12/9/11 at 05:56 PM Reply With Quote
Lucky blighters, here in East Northants it's 3 (yes THREE) Hackney tests (like MOT, but strickter) plus annual MOT.
Personally, having worked in the motor trade, been a mechanic and MOT tester, and, having seen the condition of cars that the general public are 'happy' driving around in, then I say keep it as is.
1, gentleman called in to work shop with an intermitent brake problem (Montego estate). - N/S/F wheel bearing so badly collapsed that the vehicle needed new bearing, bearing carrier (front hub knuckle), Outer CV joint, CV drive flange into bearing, new discs & pads ( N/S/F disc had fouled on calliper carrier and was damaged).
2, Older gentleman had driven his Fiat 20 miles to our test station, it needed to be tested because he spent the last year & a half in hospital and now he was out it needed testing so he could drive to the shops in Milton Keynes (I was in Bedford). the car was a 1970's Fiat and was covered in moss, I put it on the MOT ramp and when I started to jack it up at the front, the car started to bend in the middle and the sills started to open up, it was that rotten,I suspended the test, advised the customer that the was in my opinion unsafe to be on the road and given its condition, I was unwilling to do the mot test and the vehicle should be recovered away from the depot. 'Oh its all right I'll drive it slowly home' says he.
I could go on, quite easily.......
posted on 12/9/11 at 06:44 PM Reply With Quote
Following the German model which is where the idea tyre tread limit for passing the test would be raised, in effect you have to buy a full set of tyres for every MOT.
Ninehigh
posted on 12/9/11 at 09:57 PM Reply With Quote
Warrington does 6 months too, but at least it's one fee!
The tread limit isn't a bad idea, 1.6mm minimum to be legal but require (say) 2mm for MOT
coyoteboy
posted on 12/9/11 at 10:50 PM Reply With Quote
Hmmm my other half recently had to replace her rear tyres after they started cracking - 4.5mm of tread across the tyre despite 7 years of driving (60K miles) on it!
Either way, don't think it makes any sense to have 2 years between at all - I can see no argument for it.
