Author: Subject: locoblade donor car?
carnage_uk
posted on 3/8/04 at 05:37 PM Reply With Quote
I was just wandering what would be a suitable donor car for the locoblade? Also which parts will be needed?
phelpsa
posted on 3/8/04 at 05:40 PM Reply With Quote
Hello, me again
Are you planning on live axle or independant rear suspension?
Adam
Jon Ison
posted on 3/8/04 at 05:41 PM Reply With Quote
Are you building your own chassis ?
if so Cortina would be good.........
carnage_uk
posted on 3/8/04 at 05:45 PM Reply With Quote
The price on the site is £500 for the chassis, I take it that's in kit form? I think independant will be abit too much for the budget. What will be needed to fit a k-series engine? Rover hubs I take it?
phelpsa
posted on 3/8/04 at 05:48 PM Reply With Quote
No, you use the k-series engine with a Sierra type 9 gearbox and caterham bellhousing. You use the axle from a mk1/2 (rwd) escort and the front uprights and hubs from a Ford cortina mk 3/4/5. You will need to make your own engine mounts.Jon, from his other post I think he means a Stuart Taylor locoblade chassis with K-series engine.
Adam
[Edited on 3/8/04 by phelpsa]
Jon Ison
posted on 3/8/04 at 05:54 PM Reply With Quote
in that case id'e go Mk chassis, sierra doner, use all the sierra bits except engine source or make engine/box adaptor, job done.
carnage_uk
posted on 3/8/04 at 06:01 PM Reply With Quote
Jon I've added you on msn, have you got a link to the mk chassis and is it preassembled?
Jon Ison
posted on 3/8/04 at 06:03 PM Reply With Quote
http://www.mk-sportscars.fsnet.co.uk/
msn no prob, see you around.
phelpsa
posted on 3/8/04 at 06:05 PM Reply With Quote
Note, this is different to the locost design (which the ST is) and the bodywork, wishbones etc. are not interchangable.
The other one to look at is the GTS de dion. It uses a full sierra donor although I think the driveshafts are shortened.
http://www.gtscougar.freeserve.co.uk
Adam
phelpsa
posted on 3/8/04 at 06:06 PM Reply With Quote
sorry, posted it before I saw Jons post.
James
posted on 4/8/04 at 01:32 PM Reply With Quote
Adam
Nah, standard driveshafts.
Needs an Escort rack though.
James
James
posted on 4/8/04 at 01:33 PM Reply With Quote
Adam
James
phelpsa
posted on 4/8/04 at 01:34 PM Reply With Quote
Alright, alright, you only need to say it one
Adam
