Author: Subject: Stainless Steel
bbwales
posted on 13/9/11 at 09:27 AM Reply With Quote
Stainless Steel
Hi All,
I need help please, I am after a Stainless Steel disc very very shiny it needs to be 230mm dia with a 22mm hole in the middle. It is not for the car but for my shower.
Can anyone help please?
Beer tokens waiting.
Regards
Bob
Fred W B
posted on 13/9/11 at 07:29 PM Reply With Quote
I can't help, being where I am, but it would help others if you would spec the thickness required.
Generally full polished stainless is only available off the shelf in probably 1.2mm or less thickness. 2B brushed finish is easier to get.
Thicker material if required will have to be polished to spec.
Fred W B
NigeEss
posted on 13/9/11 at 07:55 PM Reply With Quote
Contact Andyw7de, he can water jet cut to your requirements.
bbwales
posted on 14/9/11 at 10:18 AM Reply With Quote
Many thanks for the advice gents.
Oh it only needs to be 1mm ish thick as it is purely for cosmetic purposes.
Bob
