Author: Subject: Twin Carbs
The Doc
posted on 18/9/11 at 11:35 AM Reply With Quote
Twin Carbs
Just fitting a pair od Dellortos. What do we do about the oil separator?
Ta
Mike
Q: Who wants to live until they're 80?
A: Someone who's 79
Confused but excited.
posted on 18/9/11 at 12:39 PM Reply With Quote
I'm not going to post 'Oil separator, on Dellorto's?' but no doubt someone will.
cliftyhanger
posted on 18/9/11 at 12:49 PM Reply With Quote
Ok, what are you referring to?
iank
posted on 18/9/11 at 01:15 PM Reply With Quote
Probably talking about the an oil breather. Answer plumb the breather into a catch tank, the engine doesn't need oily vapour in the intake.
Easy to make a catch tank from a metal drinks bottle and a small K&N style filter - much cheaper than buying a bespoke one.
p.s. don't suggest leaving the vent open, it upsets the bikers (for obvious reasons).
Anonymous
macc man
posted on 18/9/11 at 06:49 PM Reply With Quote
If you go to your local pound shop you can buy an ideal catch bottle for £1. I made mine for less than £10. (locost!)
kendo
posted on 18/9/11 at 07:52 PM Reply With Quote
Oil Vapour catcher
Agree with the above.
However, I'd suggest attaching that hose such that it feeds into the rocker cover and then have a separate vent pipe from the rocker cover going to the catch tank.
The Doc
posted on 23/9/11 at 06:09 PM Reply With Quote
More Dellorto Glitches
OK got the car running but it seems that the front carb's pump mechanism is fouling on the dizzy cap/leads below. Is the best solution a side entry cap or will this still be too tall? Is it a case of using the leads with 90 degree ends?
Also, my carbs have the central quadrant style cable set up with an adjustable linkage between the two. Ideally I'd like to get from a standard Xflow pedal fitting (ball and socket) to a nipple at the carb end, which I guess could be a solderless screw type. Don't see the need for twin cables.
Thanks in advance for any advice here
TA
Mike
A: Someone who's 79
