Author: Subject: *HELP* Hub/bearing carriers using MK indy setup
cps13
posted on 25/9/11 at 06:26 PM Reply With Quote
Starting to get frustrated now trying to find the bits I need...
I am building a Locost using MK Indy IRS setup. I have the rear wishbones and hub carriers from MK Indy. I want to have a disc brakes, so I purchased Sierra rear calipers and hub carriers however the two do not fit.
The Sierra hub carrier will not fit inside the MK indy one and the bolt holes do not line up.
Does anyone know what I need or what have you guys used? I have pics of what I've got button cannot figure out how to put an image on this post. They can be found here... http://www.pistonheads.com/gassing/topic.asp?t=995784
Will remove the pic link if its not allowed!!
lotusmadandy
posted on 25/9/11 at 06:31 PM Reply With Quote
It depends on the rear hub carriers that you have.
There are two different types,one for drums and one for discs.
The hubs on the drum uprights will mount with the bolt holes vertical,the disk hubs
are mounted on approximately a 35 deg angle and have a cut out on the top rear
edge.
Just looked at the photos and you have got disk uprights.The hub mounts with the mounting lugs facing the rear and should bolt straight on.
[Edited on 25/9/11 by lotusmadandy]
daniel mason
posted on 25/9/11 at 06:34 PM Reply With Quote
There are 2 types of caliper also I think. Make sure you have got correct parts
cps13
The hub carriers I purchased from MK are for discs, as are the ford ones as they have mountings for the calipers.
I'm not sure if I am getting confused and trying to use the wrong bits?
cps13
posted on 25/9/11 at 06:35 PM Reply With Quote
Its getting the two hub carriers to match which is the immediate problem, I will move onto caliper problems once I've solved this one
Paul (Notts)
posted on 25/9/11 at 06:49 PM Reply With Quote
Are the hubs handed eg the left hub will only fit the left upright ?
mad-butcher
posted on 25/9/11 at 06:52 PM Reply With Quote
Hopefully you can puzzle it out from the photos
[img] Description
[/img]
[img] Description
[/img]
[img] magnetic speedo sender protected from accidental knocks
[/img]
tony
cps13
posted on 25/9/11 at 07:05 PM Reply With Quote
They are.
Thanks for all your answers! Feel a tad stupid now but hey, at least its figured out!!
