Author: Subject: Best paint to use on cast iron blocks?
DixieTheKid
posted on 1/11/11 at 10:31 PM Reply With Quote
Hello all,
As above really, what was your choice and has i lasted?
Cheers Chris
COS IT'S Worth IT
tegwin
posted on 1/11/11 at 10:56 PM Reply With Quote
Frosts sell specific engine paints for that sort of thing. I know some people have used hammerite, but its really not that durable. Might as well spend a bit more and get the proper stuff :-)
www.verticalhorizonsmedia.tv
Andi
posted on 1/11/11 at 11:07 PM Reply With Quote
KLIK KLIK
The above stuff is great on blocks... It comes in a 2 pack and sets absolutely solid. 1 tin although small was enough to do the pinto.
Halfords sell it and for some reason are knocking it out for a tenner. I got 2 pots but only needed the one.
Andi
posted on 1/11/11 at 11:10 PM Reply With Quote
Smooth Hammerite.
Autosri
posted on 1/11/11 at 11:33 PM Reply With Quote
Originally posted by coozer
Smooth Hammerite.
mine is getting a couple of coats of this next weekend
Benzine
posted on 1/11/11 at 11:59 PM Reply With Quote
anything but hammerite
ever
ever
Bare
posted on 2/11/11 at 01:54 AM Reply With Quote
Seriously?? The cheapest Rattle can paint you can find. For good reason actually :-)
Cheap paint has limited heat tolerance.. Sooo IF you overheat your motors the paint will blister and bubble telling you youv'e Effed Up. BUT unless you seriously overheat the engine, the paint works Just Fine.. thanks.
Nothing worse than your engine paint failing to indicate a serious problem has occurred while you were asleep at the wheel.
Food for thought.. I would think :-)
RichardK
posted on 2/11/11 at 03:04 AM Reply With Quote
Smooth hammerite for my old pinto and new zetec over here...
No probs so far.
Rich
Gallery updated 11/01/2011
Mr C
posted on 2/11/11 at 07:43 AM Reply With Quote
simoniz alloy wheel paint and laquer if required. I did alot of research on the www and a poster on a ford forum had compared paints, this came out tops, the hotter it got the harder it became. finish is excellent for that au'natural look.
All paints tolerate the high heats associated with engines so the extreme temp paints are not required.
image below
[Edited on 2/11/11 by Mr C]
Girl walks into a bar and asks for a double entendre, so the barman gave her one
splitrivet
posted on 2/11/11 at 10:28 AM Reply With Quote
Ive used Hammerite smooth but it should really be called chipalot.
Bob
posted on 2/11/11 at 12:10 PM Reply With Quote
Very light spray with Zinc rich primer then any old cellulose or acrylic aerosol.
I can recommend Hycote "Double Acrylic" aerosol come in tiny cans but cover an amazing area and don't run as easily as most aerosol --- they are also very cheap !
DixieTheKid
posted on 2/11/11 at 01:06 PM Reply With Quote
Many thanks for all of you replies. Most helpful. Im going to start a poll on colour!
COS IT'S Worth IT
