Author: Subject: R1 tacho fault code again
athoirs
posted on 10/8/04 at 08:11 PM Reply With Quote
Hi guys , I am getting a 9000rpm fault code on my 01 R1 clocks, any ideas The Exup is all ok but I cannot find any fer to this code in the manual
ta
evo3500
posted on 10/8/04 at 09:33 PM Reply With Quote
Tacho Fault
possible low fuel sender/warning light indicates its disconected.
Ive got a thunderace fault code is 8000rpm for above fault possible on r1 its 9000rpm worth checking ? as my friend did an R1 indy he had same fault and im sure thats what was causing the problem bridge it with a small resistor keep twistin it to increase the resistance until the fault goes.let me know how you get on.
Cheers Simon
subk2002
posted on 10/8/04 at 09:42 PM Reply With Quote
I had the same problem its a 99 iv got and it was shooting up to 8000 rpm it was the fuel sender.
http://www.locostbuilders.co.uk/viewthread.php?tid=15761
Try hear
[Edited on 10/8/04 by subk2002]
athoirs
posted on 15/8/04 at 08:25 AM Reply With Quote
Hi, Got the problem sorted - the version I have has a engine cut out switch - just a tilt switch - which cuts off the fuel pump via the ecu - I had it mounted the wrong way up!
Sub K2002 you must have sold your hood'? I was the guy with the dog in his car at last years show, have you got your MK on the road yet?
subk2002
posted on 15/8/04 at 02:23 PM Reply With Quote
Hi andy isnt it?
Hows it going? Yes sold the kit to a guy from fife about a month ago. Did you get yours sold. i remember you wanted a bec so what you building?
Im finnished mk r1 indy just got to wait till sva on sep 2nd cant wait.
Cheers Drew
athoirs
posted on 15/8/04 at 04:54 PM Reply With Quote
hi Drew,
Yes it is Andy.. Sold the 2b last year to a policeman!.. building a Indy with a r1/fazer engine.. the sva is booked for the end of next week but I might have to put it back.. the car is all but finished.. have you got a cat sorted for the test yet?
subk2002
posted on 15/8/04 at 05:17 PM Reply With Quote
You have u2u andy
athoirs
posted on 24/8/04 at 07:25 PM Reply With Quote
Subk/Drew
Sorry for not getting back to you but my mother-in-law died last week so that put a block on everything, things are sorted out now and the up side is that i,ve got a couple of days off to sort the car out- the SVA have been good enough to put my date back.
subk2002
posted on 24/8/04 at 09:20 PM Reply With Quote
Sorry to here that andy.
Hope you pass the sva.
Drew
