Author: Subject: Duratec EGR tube
neilp1
posted on 17/11/11 at 07:38 PM Reply With Quote
Duratec EGR tube
Anyone know what size/type thread the EGR tube is on a duratec so can get a plug for it?
pjay
posted on 17/11/11 at 07:57 PM Reply With Quote
I'll have a look a bit later but I don't think you need to blank it off if you've got the EGR valve removed (and blanked).
Any particular reason you want to 'plug' it?
Tiger Super Six
posted on 17/11/11 at 08:07 PM Reply With Quote
You don't need to plug it but I had wanted to on mine. It's a funny thread size I believe so gave up after a while.
Mark
Tiger Avon
big-vee-twin
posted on 17/11/11 at 09:08 PM Reply With Quote
You fit a blanking plate to the rear of the head, then your inlet manifold blanks the inlet side and your exhaust manifold blanks that side, you can see the inlet side and the EGR Valve blanking plate below
[img] Duratec to Type9 Bellhousing
[/img]
http://www.triangleltd.com
neilp1
posted on 17/11/11 at 09:42 PM Reply With Quote
[/img]
My inlet manifold doesn't cover it!!
Tiger Super Six
posted on 17/11/11 at 10:18 PM Reply With Quote
No, most don't as there is no need to cover it as it is blanked off by the egr plate on the back of the engine. The exhaust side however does need to be blanked off by the manifold.
Mark
Tiger Avon
mggareth
posted on 17/11/11 at 11:40 PM Reply With Quote
hi there a M22 x 1.5 scholar engines have them on the shelf
