Author: Subject: Pure (nearly) alcohol?
tegwin
posted on 12/12/11 at 03:39 PM Reply With Quote
I have built a fire eating engine as a Christmas present for my father.
It does not want to run on Meths, I suspect because the flame is not hot enough.
Anyone know where I can get 96-98% proof alcohol to burn instead? Have tried screwfix/toolstation etc... where locally am I likleley to find such a thing?
www.verticalhorizonsmedia.tv
ken555
posted on 12/12/11 at 03:48 PM Reply With Quote
Ebay ?
jossey
posted on 12/12/11 at 03:50 PM Reply With Quote
could you use 98% isopropyl alcohol which is easy to get from like builders merchants etc. i get it from my local diy shop....
David Johnson
tegwin
posted on 12/12/11 at 03:57 PM Reply With Quote
None of the local places I tried have Ispopropyl I know it contains some water and some methanol.... But will it still be hotter than purple methylated spirit?
tegwin
posted on 12/12/11 at 03:59 PM Reply With Quote
Originally posted by ken555
Ebay ?
You need a government certificate to buy that!!!!
Confused but excited.
posted on 12/12/11 at 04:10 PM Reply With Quote
Surgical spirit from a chemists? It's 95% Industrial meths, no purple crap and it's got 2.5% virgin castor oil for that retro two-stroke smell.
Or you could make a simple still but watch out for them revenooers.
[Edited on 12/12/11 by Confused but excited.]
tegwin
posted on 12/12/11 at 04:17 PM Reply With Quote
Hmm... not sure castor oil is a good idea... its an alloy cylinder with graphite pistons.... Any oil residue will bung it up....
Just need something that provides a good hot flame with little else... (water vapour is ok)....
chrsgrain
posted on 12/12/11 at 04:23 PM Reply With Quote
You need someone nearby who works in a scientific research lab, we use gallons of properly pure (99.999%) alcohol.... I don't know if it burns any hotter than meths though.
Sigma chemicals in Poole might be able to help you??
Chris
matt_gsxr
posted on 12/12/11 at 04:24 PM Reply With Quote
Meths is pretty much the same as ethanol:
from Wikipedia
Denatured alcohol or methylated spirits is ethanol that has additives to make it more poisonous or unpalatable, and thus, undrinkable. In some cases it is also dyed.
Or NHS poisons unit
http://www.southend.nhs.uk/pathologyhandbook/clinical_chemistry/Guidelines/methylated_spirits.htm
Autosri
posted on 12/12/11 at 04:33 PM Reply With Quote
Ipa is good and can be got from maplins electronics it's electrical contact cleaner
bi22le
posted on 12/12/11 at 05:15 PM Reply With Quote
RC model fuel with super-low caster oil content?
I know it will have caster oil in which you dont need but that stuff is designed to burn hot hot hot!
Please read my ring story:
graememk
posted on 12/12/11 at 05:18 PM Reply With Quote
have a look on youtube and ask some of the other guys what they are using
bobinspain
posted on 12/12/11 at 05:43 PM Reply With Quote
Spectroscopic alcohol is virtually 'pure.' ethanol. C2H5OH.
We used to sup it, (hugely diluted with fruitjuice) at Uni parties in the 60's.
The Shootist
posted on 12/12/11 at 06:32 PM Reply With Quote
Touchy models "Flame Lickers"
Flame Lickers or vacuum engines are a touchy class of model.
Very light oil applied to the bearings, and denatured alcohol. Other fuel will smoke and soot up the inside of the engine making things worse.
If the engine is new it will require a lot of run-in to get it loose enough to run reliably.
Try a model engineer's website for more info.
[Edited on 12/12/11 by The Shootist]
designer
posted on 12/12/11 at 06:36 PM Reply With Quote
What about parafin?
loggyboy
posted on 12/12/11 at 06:37 PM Reply With Quote
Remember 100% 'proof' alcolohol isnt 100% alcohol-
http://en.wikipedia.org/wiki/Alcohol_proof
Lightning
posted on 12/12/11 at 10:36 PM Reply With Quote
I ve got some 125% proof rum.
