New Topic New Reply
Author: Subject: protec shocks
ajw
posted on 15/12/11 at 08:57 PM Reply With Quote
protec shocks
just fitted double adjustable shocks. Arrived with spring rest plate and adjustable plate to sit spring on and adjust same .
question? how do I lock adjust plate from screwing loose.
westf27
posted on 15/12/11 at 09:14 PM Reply With Quote
should have a small grub screw in the rotating plate.
555
hobbsy
posted on 15/12/11 at 09:15 PM Reply With Quote
If you mean the two halves of the spring platform you just do one up against the other
afj
posted on 15/12/11 at 10:34 PM Reply With Quote
They don't unscrew on their own, well mine don't
eerrrrrrrrrrrrrrrr
noc231073
posted on 15/12/11 at 10:51 PM Reply With Quote
Alex the weight of the car will keep them locked in place no need for anything else
procomp
posted on 16/12/11 at 01:09 PM Reply With Quote
Hi
As said they do not move when they are preloaded with spring pressure. However if you a situation where the spring has no preload during droop travel they will sometimes move small amounts. Which is why i offer the option of having a grub screw fitted when ordered from myself.
Other notes, are you fitting them to the front of a Indy R. If so have you had the needle valve changed and valving set to suit. If not you will retain the same basic problem as the single adjustables have.
Cheers Matt
ajw
posted on 16/12/11 at 06:22 PM Reply With Quote
protech shocks
No grub screws on the shocks. If I put a ziptie tight against base of adjuster plate once final setting achived might keep in place.
New Topic New Reply
