charlie_pank
| posted on 17/12/11 at 03:36 PM |
Fixing bits (eg ECU) to chassis
Does anyone have any suggestions for this? I don't think I can drill any holes in the ECU, but really need it to be firmly secured. Same with
bike fusebox etc... What have other people done for this?
Charlie
ReMan
| posted on 17/12/11 at 03:59 PM |
If you cant use the original fixings or modify them, then bent ali brackets are usuall enough, with a bit of foam/rubber to keep them snug
www.plusnine.co.uk
r1_pete
| posted on 17/12/11 at 05:50 PM |
I've fitted my Megasquirt box behind the dash with double sided adhesive number plate strips.
[Edited on 17/12/11 by r1_pete]
Coopz
| posted on 17/12/11 at 06:03 PM |
With the ecu I made an ally bracket up with foam tape inserts, then decided it didn't look great so I used some extra strong velcro on a chassis
rail hasn't budget and easily removable. The rest of the bike loom parts are either riveted or cable tied on a plate underneath the bulkhead.
