laptoprob
posted on 19/12/11 at 09:37 PM |
Duratec clutch/flywheel setup
My brother has just bought a 2.0 Duratec to put in his R6 and need a little info on flywheel clutch combo`s available to him using a type 9.
He is probably going to run a std engine for now with 45`s so if he is lucky then around 180 bhp.
What does he need?
Locost in mind for now please
[Edited on 19/12/11 by laptoprob]
http://www.youtube.com/watch?v=ajlF4nWJtGA
andylancaster3000
posted on 19/12/11 at 10:11 PM |
I believe we used the ST150 flywheel, with a standard mondeo/st150 flywheel (not sure they are the same) with a specific AP drive plate for the job
that was in the order of £40-50. I will try and get the part number of the drive plate.
laptoprob
posted on 20/12/11 at 08:11 AM |
That would be great thanks.
big-vee-twin
posted on 20/12/11 at 09:16 AM |
ST150 Flywheel, Heavy Duty Pinto Friction Plate, Heavy Duty RS Turbo pressure plate, SAAB thrust bearing.
http://www.triangleltd.com
laptoprob
posted on 20/12/11 at 10:04 AM |
Can you not use the Zetec pressure plate and a std RS2000 bearing?
pjay
posted on 20/12/11 at 12:02 PM |
Big Vee Twin,
Do you have a part number handy for the "Heavy Duty RS Turbo pressure plate"? Pinto friction plate would be AP CP5352-5 I IIRC?
Laptoprob,
With the ST150 flywheel I don't think the standard Mondeo/Focus type starter will fit (IIRC) - obviously ST150 starter would though.
Are you thinking cable or hydraulic clutch?
Other flywheel clutch options aren't cheap but you could use a Titan lightweight flywheel (4.7kg or even lighter), Pinto friction plate (as
above) and clutch cover. Need to make sure clutch cover and flywheel have matching PCD since there are different combinations.
laptoprob
posted on 20/12/11 at 01:03 PM |
quote: Originally posted by pjay
Big Vee Twin,
Cable op for sure at the present.
Titan version is lovely but it needs to be on a tight budget at present.
Can i not use the zetec flywheel etc?
big-vee-twin
posted on 20/12/11 at 01:33 PM |
You can use an older Zetec plate, but if you like doing Duratec on Throttle bodies the BHP exceeds standard pressure plate,
I got mine from Techni clutch, also when you use a FWD clutch plate the fingers are too long and have to be shortened to allow the Thrust brearing
Tube to fit.
If the pressure plate fingers are flat you need to use a curved bearing, if they are curved you can use a flat bearing.
I used the Titon Bell housing and Hydraulics/Bearing.
[img]
![](/galpreviews/Techniclutch .jpg) ![RS Turbo clutch Duratec](/gallery/Techniclutch .jpg) RS Turbo clutch Duratec
[/img]
[img]
![](/galpreviews/hydraulic clutch slave2.jpg) ![Duratec clutch cylinder](/gallery/hydraulic clutch slave2.jpg) Duratec clutch cylinder
[/img]
Yes the standard starter doesn't fit, you can machine the mating surface to make it fit however, needs 2-3mm removing
[Edited on 20/12/11 by big-vee-twin]
pjay
posted on 20/12/11 at 03:50 PM |
In terms of cable clutch are you looking something like this?
http://www.rwdmotorsport.com/Bellhousings/Duratec-Engine-to-Ford-Gearbox-Cable-Clutch-Bellhousing/prod_19.html
laptoprob
posted on 20/12/11 at 03:52 PM |
Thats the one i will be buying unless one comes up on here or ebay.
laptoprob
posted on 20/12/11 at 06:37 PM |
Sorry to be stupid but just to re-cap...the ST150 flywheel and starter along with the pressure plate and cover from a Pinto will work ok? (upto say
180 bhp?)
big-vee-twin
posted on 20/12/11 at 08:25 PM |
Friction plate from a Pinto and Pressure plate from early Zetec or similar.
pjay
posted on 20/12/11 at 09:25 PM |
One other thing to check for with the cable clutch is the pivot point for the release arm. I had to make a new pivot pin because the orginal from RWD
is designed for the depth of the Titan FW + Pinto clutch cover but my set up was with a different clutch cover and was shallower.
Looking at the ST150 FW it may be thicker than the Titan FW so may go the other way. You could check the RWD guys and see what they think.
Wasn't too difficult to sort though.
laptoprob
posted on 20/12/11 at 09:39 PM |
PJAY+BIG-VEE you`ve been a great help, thanks very much
big-vee-twin
posted on 21/12/11 at 10:05 PM |
No worries, without getting help from others on here, I wouldn't have learn't and been able to pass on the info.
Kev
