Author: Subject: OBP Pedal Box
wombat
posted on 20/12/11 at 09:58 PM Reply With Quote
OBP Pedal Box
Evening, bought an OBP Pedal Box and would like to know how you folks have made throttle and clutch cable pedal connections using this?
Pics would be helpful.
I have the sheets from OBP but would like to see how you have done it....
Type 9 = Capri cable I think from my searching on here..
Ta in advance
ChrisLeary
posted on 20/12/11 at 10:39 PM Reply With Quote
Ta in advance
Sorry to hijack your thread, but i'll be watching this as i've just taken delivery of my obp pedal box too.
At the minute i'm planning on using a cortina clutch cable with a bolt through the polo shaped nipple end at the pedal,and then normal fitment at the gearbox end. But i'm really unsure how i'm going to go about sorting the throttle.
ATB, chris.
mikeb
posted on 20/12/11 at 11:39 PM Reply With Quote
Just made a bit to fit mine for the Capri clutch cable, basically a flat plate with a 45 deg tube welded on. It bolts onto the holes for the hydraulic master, I'll get some pics up tomorrOw, not sure about throttle, thinking it will go vertically.
What size master cylinders did you get?
wombat
posted on 21/12/11 at 06:59 AM Reply With Quote
I picked up box last friday as I live nearby, unfortunately I was in a rush and it wasnt till Saturday when I looked at cylinders, discovered I had two 7's.
Sam at OBP apologised and swapping for .625 between xmas and new year.
Any pics would be great help..............visual learner etc :-)
ChrisLeary
posted on 21/12/11 at 10:52 AM Reply With Quote
I got two .7s, but when reading around on the help pages it states .625 should be used for the front part of the system. I rang them and recieved a new one 2 days later.
Some pictures of your clutch setup would be a huge help.
ATB, Chris.
mikeb
posted on 21/12/11 at 03:42 PM Reply With Quote
IMAG0341 by mjb22001, on Flickr
here you go
karlak
posted on 21/12/11 at 03:55 PM Reply With Quote
Does it simply have the cyclinder type written on it somewhere - I will need to check mine.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
ChrisLeary
posted on 21/12/11 at 04:51 PM Reply With Quote
On the OBP ones it's cast into the sides of the master cylinder.
ATB, Chris
wombat
posted on 21/12/11 at 06:37 PM Reply With Quote
Thx for picture Mike, helps a lot.
Any pics of throttle link locosters???????
wombat
posted on 2/1/12 at 04:49 PM Reply With Quote
Clutch cable
Is this what I need to connect Type 9 to OBP Pedal Box?
Advertised without part numbers but ''allegedly for escort/capri/cortina''
big_wasa
posted on 2/1/12 at 05:20 PM Reply With Quote
Yep I removed the damper bit of rubber. Obp used to have some good fitting instructions on there site.
I drilled a hole in the bottom tube in the chassis and welded a tube through it that the cable just presses into.
I drilled and taped to m6 a few holes in the clutch pedal. A small differance makes a big differance to the leverage and the feel.
A high tensile nut bolt and a couple of washers either side of the cable eye.
You then need a spring between the pedal and the box to stop the pedal falling forwards. Others have used a stop.
I also cut a face out of the locking nut so I could hold the cable better to the bell housing.
Photo shows mock up. Ive since fully welded the tube and used a longer capri cable.
[Edited on 2/1/12 by big_wasa]
wombat
posted on 2/1/12 at 05:25 PM Reply With Quote
Cables
Thanks wasa, yes got the fitting sorted.
Any ideas on how to attach throttle cable to this type of pedal?
OBP site shows a different type of pedal..
big_wasa
posted on 2/1/12 at 05:43 PM Reply With Quote
No mine is differant to yours. Got any better pic's ?
Not got the hydraulic clutch pedal box have you ?
wombat
posted on 2/1/12 at 05:51 PM Reply With Quote
Clutch connection not an issue, def cable version.
big_wasa
posted on 2/1/12 at 06:12 PM Reply With Quote
Like you say the clutch is easy.
The photo looks like the throttle pedal pushes forward so you need some kind of linkage to reverse the push to a pull ? I
I would be giving them a ring and asking.
wombat
posted on 2/1/12 at 08:27 PM Reply With Quote
Yep, lever arm pulls downwards as you depress pedal.
Will have to give them a call again, last time they directed me to help sheet.
Ta anyways.
