vananddan09
posted on 21/12/11 at 12:39 PM |
mk indy mushroom insert, where to put them??
Does anyone no which way the mushroom inserts in the front uprights are ment to face, mine are facing towards inwards to the left as if they are
facing the headlights, ive read afew different things, most say they are ment to face towards the front of the car, When u adjust these it adjusts the
KPI does anyone no what the kpi is ment to be set at or is everyone just guessing, If they was facing the front of the car that would mean you have
more KPI and the car would be more stable in a straight line at high speed but the car wouldnt turn in as fast, If you had them facing the rear of the
car which means less KPI the car would turn in faster but would be less stable in a straight line at high speeds which would throw you all over the
road, Thats why i set mine inbetween so i have best of both worlds but im just guessing, can anyone help, Thanks
mookaloid
posted on 21/12/11 at 12:45 PM |
The holes go towards the front.
This helps with self centreing.
Mark
vananddan09
posted on 21/12/11 at 01:06 PM |
Hi mate thanks for that, from what i have read on internet that seems to be where everyone puts them, think ill change mine at weekend, thanks again![](/images//smilies/bigsmile.gif)
posted on 21/12/11 at 03:23 PM |
And it doesn't adjust the KPI, there are dozens of threads on here that explain why.
posted on 21/12/11 at 03:45 PM |
Other way round: it will change the KPI v camber relationship but will not effect the caster angle. It also has a small effect on trail.
vananddan09
posted on 21/12/11 at 04:37 PM |
Well this just shows that people on here dont no what they are talking about, When you turn the mushroom it adjusts the kpi(caster). I have just spoke
to MK and they comfirmed that is exactly what is does![](/images//smilies/tongue.gif)
tomgregory2000
posted on 21/12/11 at 04:47 PM |
it does NOT adjust the caster, it adjusts trail
vananddan09
posted on 21/12/11 at 05:09 PM |
i was told to adjust the trail you need to adjust the castor to do it, can someone explain
posted on 21/12/11 at 05:21 PM |
Caster angle gives trail effect BUT you can have physical trail with zero caster angle ie. shopping trolley casters have trail but no caster
angle.
[Edited on 21/12/11 by britishtrident]
posted on 21/12/11 at 05:35 PM |
I think the confusion lies between King Pin Inclination and Caster Angle --- they are different angles that define the virtual king pin.
Adjustable mushrooms change the KPI relationship to the Camber angle.
The caster angle is defined by the relative position of ball joints when viewed from the side of the car ----
Altering KPI will not change the Caster Angle. Adjustable mushrooms cannot not alter caster angle.
posted on 21/12/11 at 05:37 PM |
Simples you were given bad info.
