Gti6boy
| posted on 21/12/11 at 08:16 PM |
R1 baffle plate problem?
After fitting a baffle plate in the sump my oil light is on for around 5mins on idle. As the engine warms up the light go's out
Anybody else experience this?
Nick
a4gom
| posted on 21/12/11 at 08:23 PM |
yes, mine does it.
Perfect planning prevents pi$$ poor performance!
hobbsy
| posted on 21/12/11 at 09:02 PM |
It kinda makes sense as when the oil is thick it can't return to the very bottom of the sump as quickly.
I didn't experience this as I chopped off my oil level sensor because I didn't want to cut a massive hole in the baffle plate and weaken
it (my original one was poorly made and breaking up).
How much of an overfil are you running?
Gti6boy
| posted on 21/12/11 at 10:22 PM |
Well I changed the oil filter and had the sump off for a week dripping while waiting for a new sump (speedhump!), and I put 4lts back in
hobbsy
| posted on 22/12/11 at 01:48 AM |
The recommended overfill is 250ml above the normal level. You may need a bit more depending on which year of engine and if you filled up your filter
etc.
Gti6boy
| posted on 22/12/11 at 08:17 PM |
I think the engine takes 3.8lts dry so just poured the bottle in. Shall i Maybe put some more in then?
bassett
| posted on 22/12/11 at 10:02 PM |
Hi, i have never had any problems with mine even when cold. Do you have that relief tulip fitted? when i was reading about fitting mine a lot of
people recommended not to fit it so i didnt and has been fine for over 4k. As others have mentioned overfill when cold by 250ml and i think when i
removed the sump and filter i replaced more than 4ltrs of oil.
Adam
Gti6boy
| posted on 22/12/11 at 10:54 PM |
Is the relief tulip the metal tube in the sump around 100mm long?
I will put a bit more oil in and see how that go's
