AndyW
posted on 26/12/11 at 10:03 AM |
Zetec blacktop 2.0 cooling hoses
First of all, Merry Christmas to all locosters!!
Now the mad day has gone, i can think about the cooling for my car. I now have a new rad (polo) and fan
What I need to get now are the hoses and pipes to plumb it in. Where is the best place to buy them all? ebay?? Also what type of pipes? silicone or
rubber. Also what size and length of ali pipes etc. Im running a standard blacktop 2.0 setup with standard thermostat housing.
Any help and advice always appreciated.
big_wasa
posted on 26/12/11 at 10:32 AM |
The pipe work will depend on where you put the header tank if your using one ?
The polo rad and zetec stat' housing are 32mm. Water pump on silver top is bigger but I think black top is 32mm aswell.
Ive used a flexi silicone for most of mine.
You need a bit of 32mm tube with two spures. One for the bypass and one for the header tank. I used steel as its cheap and I can weld it. This goes
between water pump and bottom of rad.
Ive used another 32mm tube from the stat to the top of the rad. Again steel so I can weld bosses into it for things.
Stat bypass fromm memory is 22mm. This goes to the spure in the bottom hose.
Russ Bost on here will do you nice alloy ones to your size with the ends beaded for not much dosh and with great service.
AndyW
posted on 26/12/11 at 10:40 AM |
Thanks Warren...
dunk3
posted on 26/12/11 at 11:01 AM |
Hi Andy, i got my silicone hoses from these guys on ebay, Auto performance silicone hoses . I bought (1 metre 32mm , 2metre 22mm , 1 metre 8mm , 3
elbow 90 degrees 32mm , 3 elbows 90 degrees 22mm , 1 elbow 135 32mm, 1 elbow 90 degree reduced from 22mm to 18mm for the header tank. If you have a
look in my photo archive under the radiator folder there are some pics of my set up . forgot to say i used some 32mm alloy pipe from B&Q to join
the hoses together , and i had a 32mm pipe made with two 22mm T pieces welded on for the bottom radiator hoses to the water pump.
Dunk.
[Edited on 26/12/11 by dunk3]
AndyW
posted on 26/12/11 at 11:05 AM |
Cheers dunk, very helpful!!
posted on 26/12/11 at 11:14 AM |
I used a couple of silicone bends off the bay and cut the ends off to connect the straight bits. A piece of 32mm ali aerial pole from B&Q and some
15mm copper for the bypass. Header tank is at the front feeding into the bottom hose close to the rad well away from the bypass entry point.
lewis
posted on 26/12/11 at 11:28 AM |
Silicone hose & alloy pipe bought from ap performance (auto performance ) on eBay best prices and quick delivery
Double tee piece made from a guy on eBay cost £20 in alloy custom made to my dimentions/design I can dig the guys name out if you want.
I am a driving god!..........sort of
