New Topic New Reply
Author: Subject: Brake Upgrade advice pls?
z3mjason
posted on 9/1/12 at 05:22 PM Reply With Quote
Hi All,
Well I have just finished my Hayabusa conversion and its all looking very very nice!! Will get some pics up soon....
Advice please: I have single pot calipers on the front of my car (fitted by previous owner) and they just do not provide anything like the breaking power I want. Having spent a fairly hefty amount of money on the car recently I am for the time being ruling out 4 pot Wilwood conversions but would like advice on what Ford calipers and agressive pads I could use to give me the breaking I need?
My current (new) master cylinder is from an Escort apparently.
Look forward to any help/advice!
Many thanks
Jason
[Edited on 9/1/12 by z3mjason]
SALAD
posted on 9/1/12 at 05:38 PM Reply With Quote
I've done rather a lot of searching and questioning on brakes recently so to start off I would say:
Smaller bore master cylinder perhaps and a lot of people reccommend Mintex M1144 pads.
If you do a search there is a LOT of information covered on brakes.
wilkingj
posted on 9/1/12 at 05:39 PM Reply With Quote
Just remember to adjust the back to front ratio when upgrading just the fronts.
Last thing you want is an unstable car on braking.
Best Regards
Geoff
http://www.v8viento.co.uk
A1
posted on 9/1/12 at 10:01 PM Reply With Quote
ferrodo racing ds2500 compound pads are the proverbial shiz niz.
bassett
posted on 9/1/12 at 10:05 PM Reply With Quote
I had some Wilwood smart pads and upgraded to Mintex 1144 which are in a different league and i actually feel safe stopping even if they do squeel like a piggy. Along with the brake engineering drilled discs and the wilwood 4 pot calipers at the front with standard sierra gear a the back i am now really happy with the setup.
As i have just seen in the above post the ferrodo DS2500 are great pads and they have found there way onto my Leon Cupra R with great results but i found them impossible to obtain unless i made a minimum order of 5 ha!
[Edited on 9/1/12 by bassett]
z3mjason
posted on 9/1/12 at 10:11 PM Reply With Quote
Thanks very much folks!
I will try new DS2500 or Mintex 1144's before changing master cylinder or calipers.
Can anyone provide a link to the actual ones I need, apologies but not to upto speed with Ford calipers and fitments?
Many thanks, Jason
posted on 9/1/12 at 10:13 PM Reply With Quote
Covered many times just start by changing the master cylinder to a smaller bore type ----- 19mm bore from various Fiat models are the popular choice and dirt cheap from Brakes international.
See this thread http://www.locostbuilders.co.uk/viewthread.php?tid=164431
posted on 9/1/12 at 10:20 PM Reply With Quote
Can anyone provide a link to the actual ones I need, apologies but not to upto speed with Ford calipers and fitments?a
Many thanks, Jason
Master cylinder change is the cheapest (less than £30) mod and the one to do first it will reduce required pedal force by approximately 1/3 and greatly improve feel.
Larger hydraulic area calipers on the front on a BEC not a good idea it will result in premature front locking especially in the wet
z3mjason
posted on 9/1/12 at 10:35 PM Reply With Quote
Cheers for that, I did a quick search but missed that thread. Cheers
New Topic New Reply
