mad-butcher
posted on 10/1/12 at 05:16 PM |
I feel robbed
Just put my old Mitsi Pajero through it's MOT, advice on 1 brake line, went to the office to pay and get my certificate, fcuk me what a scabby
bit of paper.
tony
blakep82
posted on 10/1/12 at 05:18 PM |
yeah, still a bit of paper though, like the last one was still a bit of paper
________________________
owelly
posted on 10/1/12 at 05:19 PM |
But newer MOT is a paper piece of paper.....
http://www.ppcmag.co.uk
jollygreengiant
posted on 10/1/12 at 06:26 PM |
........................With NO sticky label.
[Edited on 10/1/12 by jollygreengiant]
Talon Motorsport
posted on 10/1/12 at 07:21 PM |
Yes but the new MOT piece of paper that the testing station gives you is only a recept and now all the faults and minor advisories are passed on to
VOSA! So next time you decide to drive around for a week after failing the test and get stopped by plod they will tell you why they impounding your
car and making you walk home. Also every warning light on the dash must work, all tow balls will be checked and so will the lighting and caravan
charging sockets.
pmc_3
posted on 10/1/12 at 07:28 PM |
The garage told me it was VOSA saving money as they were having to provide the paper. Now its just normal A4 sheets the garage has to pay for them.
jacko
posted on 10/1/12 at 07:42 PM |
charging sockets.
Yes don't i know it my airbag light is on and the part it repair it is £204 + vat + £66 + vat to fit in ![](/images//smilies/mad.gif)
just so the mot man can give me a bit of paper
donny
posted on 10/1/12 at 08:38 PM |
My P plate Clio airbag warning light has been on for the last 5 years (proves it works?!) - I was told that these were exempt so never bothered paying
to get it fixed. If VOSA have moved the goal posts then I guess there could be an attempt at a mid engined Clio based Locost.... as it will cost more
to fix than it's worth. Cheers VOSA.
Donny
adithorp
posted on 10/1/12 at 09:08 PM |
Your MOT has been held as didgital data on VOSAs computer for years. Ever since the MOT station computerisation. The green printed version was no more
"an MOT cert" than the current one. That was introduced to remove the security problems that meant stolem blank certs' had such high
value. All the fail points and advisories have been on VOSAs system all that time as well.
Like the posters on, here many didn't understand that and took it as the MOT. The new "crappy" one means people are far more likely
to check the validity of the "cert" when buying a car; Would you trust it?
http://jpsc.org.uk/forum/
eddie99
posted on 10/1/12 at 09:16 PM |
If a warning light is on??? Seriously.... Thats all alfas including mine will be off the road very quickly!
mad-butcher
posted on 10/1/12 at 09:32 PM |
good point Adithorp, but having said that how many plonkers won't check the website, I beleive any warning light, oil leak are a fail
loggyboy
posted on 10/1/12 at 09:39 PM |
Donny
I wouldnt say moving the goal posts, just making the goal smaller!
Check all the cables under your seat, its common clio problem, usually a loose connection.
posted on 10/1/12 at 09:58 PM |
i once had 11 lights on on the dash of my sprinter.
My fuel gauge has also broken, so the warning light is always on. They cant fail it for that! Sadly, there's also the service and airbag lights.
