stevebubs
posted on 20/1/12 at 10:18 PM |
Just fallen foul of the new MOT Rules - be aware
Sister-in-law's car failed today on 4 items:
O/S CV Boot - small split
N/S CV Boot - small split
Track Rod Ball Joint Gaiter - small split
Lower Balljoint Gaiter - small split.
Thought the guys was being picky with her when I found out until I got home and did a bit of research...
http://www.theaa.com/motoring_advice/car-servicing-repair/mot-changes-2012.html
froggy
posted on 20/1/12 at 10:25 PM |
these are all advisable items so unless the boots are trashed i would still advise them . cv boots are pretty straight forward if the grease is all
over the place its a fail but a little split with little mess would be an advise for me.
the other thing is the abiltiy to fail brake discs for wear is back too as this was removed last year .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
steve m
posted on 20/1/12 at 10:26 PM |
Even a small split in a cv/gaiter boot, WILL get larger very soon, and in 12 months time on the next MOT the item would be well shagged
and if the car involved had 4 tiny splits as you say, i would say, the mot guy was correct in failing the car
froggy
posted on 20/1/12 at 10:54 PM |
The mot is an assessment of the vehicle on the day it comes in and unless I can predict the condition of a mechanical component in 28 days it's
pass and advise , no doubt a small split will get bigger but it's the presenters responsibility to maintain the car not mine to make the car
roadworthy for the next year . I give the information it's up to the owner to decide to tackle things before they get worse .
posted on 20/1/12 at 11:03 PM |
New MOT rules???? what do you mean by that?
All then fails are old stuff, had all that stuff years ago when I had 1.6D Astras....
PSpirine
posted on 20/1/12 at 11:04 PM |
When I was failed on a split CV gaitor I was genuinely thankful. Not something I noticed, and it had already started to deteriorate the CV joint
itself. Fairly easy to change and only costs a couple of quid.
Consider it an early warning preventing you from having to swap out a CV joint
Balljoints and track rods will get ruined just as quickly if the gaitor is split.
Obviously an advisory would've been more pleasant, but I'd swap all of those out either way!
froggy
posted on 20/1/12 at 11:07 PM |
The ones that are new are any damage to the little boots on track rods , ball joints and anti roll bar drop links which could be expensive if you have
alloy wishbones that come with the ball joint fixed in , there are some kits to replace the boots but it's still a pita .
paulf
posted on 20/1/12 at 11:32 PM |
I have successfully repaired small splits with super glue or sika flex in the past, if cleaned and degreased with brake cleaner or similar and good
quality super glue used it is possible for small splits.
Paul
gazza285
posted on 21/1/12 at 12:25 AM |
Reading the rules my van will fail, all bar one of the dash lights have failed.
coyoteboy
posted on 21/1/12 at 02:05 AM |
pass and advise ,
This is interesting, I'd agree, that's what advisory's are for, but I did find someone somewhere who was an MOT guy who was failing
people on sometihng he was sure would fail within a year.
coyoteboy
posted on 21/1/12 at 02:17 AM |
I'm even more curious now - assuming a kit car with rose jointed suspension pivots all round, and so no rubber boots, is that a fail? assuming
you were designing the suspension properly and had a captivated spherical as top and bottom outboard joints instead of rod ends, I can't find
any boots that would securely cover that sort of joint.
[Edited on 21/1/12 by coyoteboy]
Ninehigh
posted on 21/1/12 at 04:21 AM |
pass and advise ,
The past 6 MOTs I've put the Mondeo through have required a tail/brake bulb... Would this guy thus just fail it as a matter of course?
chrisbeale
posted on 21/1/12 at 10:15 AM |
Seats must move forward and aft in at least 2 positions...... Mine are bolted down in one position. Surely I don't have to fit runners?
stevebubs
posted on 21/1/12 at 11:10 AM |
Just had the car up on ramps and had a quick look.
The TRE and Wishbone ball joint gaiters are perished but not yet split all the way through.
One CV Boot is missing a clip and hence loose (defo a valid fail)
The other CV boot has very minor nick in it
Most MOT testers I've had would have failed point 2 and made the rest advisory....but then she didn't go where I recommended but where her
"mate" works
flibble
posted on 21/1/12 at 11:16 AM |
I asked that question of an MOT tester I know well and he assured me that it's only for seats that move, Ie. if you slide the seat forward/back
and it wont lock, just slides of it's own accord, then it'd fail (obviously), fixed seats are fine ![](/images//smilies/smile.gif)
ChrisW
posted on 21/1/12 at 11:30 AM |
I also believe that, as of 1st Jan, any warning light on the dash is a fail. My Audi was moaning about brake pads so I made sure I took it in before
the new year. Plenty of 'meat' on them, the tester remarked that from what he saw he would normally have told me they were getting close
but wouldn't have put an advisory, but if I'd have brought it in 48 hours later it would have been a fail under the new regs.
Chris
My gaff my rules
macc man
posted on 21/1/12 at 12:29 PM |
Dont forget we are in a recession and any excuse for extra work on customers cars cannot be missed. I only use my local guy because I trust him, I
have been ripped off by others in the past. Beware there are stiil rogues out there.
PSpirine
posted on 21/1/12 at 01:33 PM |
If the warning lights thing is true, I suggest you top up all your fluids - new cars have a warning light for everything..
ChrisW
posted on 21/1/12 at 08:41 PM |
It's true! I was even warned that my Mrs' car should be failed because the washer fluid warning was on. Luckily he had a hose pipe very
close by...
Chris
My gaff my rules
posted on 21/1/12 at 09:51 PM |
CV joint gaitor even a small slit has been a fail for a long time with good reason.
posted on 21/1/12 at 09:54 PM |
Paul
Yes that works.
posted on 21/1/12 at 09:59 PM |
In the old days it was not unknown for cars to to come for MOT with the seats not bolted down in any way.
froggy
posted on 22/1/12 at 10:54 AM |
nothing in the guide says that a small slit consitutes a fail , the wording says deteriorated or insecure so that it no longer prevents the ingress of
dirt , to me a small split isnt a fail unless the boot is covered in cv grease
coyoteboy
posted on 23/1/12 at 10:30 AM |
The bolted down seat one is another issue - manual could read two ways. There's a clear indication that an adjuster mechanism must work
correctly, but the top of the page says original designs are to be accepted.
posted on 24/1/12 at 10:54 PM |
Yep loads of older vehicles didn't have adjustable seats even after the vintage era -- GPO vans, Ex-army vehicles.
