Author: Subject: this looks ok for a doner saab turbo
imp paul
posted on 23/1/12 at 07:57 PM Reply With Quote
http://forum.theimpclub.co.uk/viewtopic.php?f=69&t=20770 would make a nice kit go well hope this is of use to some one maybe
cheers paul
computid
posted on 23/1/12 at 08:01 PM Reply With Quote
Isn't the 9000 front wheel drive though?
Unless you just want the engine of course.
big_wasa
posted on 23/1/12 at 08:03 PM Reply With Quote
Yeh bargain but 210k is a tad high on the milage
Engine and ecu/loom and scrap the rest.
imp paul
posted on 23/1/12 at 08:06 PM Reply With Quote
yep it is but good engine to fit to another box maybe. some lads on here have saab turbos in there kits. so there must be a way lol just thort you lads mite have a use for it so put the link here
PSpirine
posted on 23/1/12 at 08:10 PM Reply With Quote
Bolts up to a R28 Omega gearbox I believe for RWD application
I was so tempted to buy that thing but restrained myself.
Also, those wheels would make an awesome retro locost! (4x108 pcd I believe) A bit big, mind..
contaminated
Vauxhall Omega box bolts on - sorted!
Tiger Super Six Independent
www.southernkitcars.com
contaminated
posted on 23/1/12 at 08:11 PM Reply With Quote
Beat me to it by seconds
flibble
posted on 23/1/12 at 08:12 PM Reply With Quote
(SAAB B234 engine + Vaux Omega gearbox = RWD) + £30 ecu mod = 280bhp = Happy
Not a bad price either.
Edit: Dohh...really slow typer
[Edited on 23-1-12 by flibble]
GRRR
posted on 23/1/12 at 08:26 PM Reply With Quote
For the benefit of anyone who fancies trying this engine and box combo and is doing a forum search some months from now, see my build blog GBS Zero build blog
Link fixed!
[Edited on 23/1/12 by GRRR]
ashg
posted on 23/1/12 at 08:28 PM Reply With Quote
its a bit expensive to be honest unless there are loads of good parts on it to make money back on.
i paid £150 for my saab turbo engine fully dressed with turbo and and all the gubbins out of the engine bay. £40 for the omega box. add ecu intercooler new prop and a custom spacer to make the saab clutch work on the omega box and you have +200 bhp
the real issue with it though is that the engine is bloody tall. i tried to get the 2.3 in my car and the bonnet would have had to be stupidly huge, eventually gave up and put a 2.0 version in which was a bit shorter but not much. no regrets as its still properly properly fast.
by far the biggest issue i had with it was shortening the sump correctly. i had to hack a good 4 inches off the sump which lead to oil starvation issues on hard acceleration, after killing the first engine i sussed it out and built a fully gated sump for it, since then no issues other than a blown turbo which is always a risk with a turbo car.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
ashg
posted on 23/1/12 at 08:30 PM Reply With Quote
linkey no workey
ashg
posted on 23/1/12 at 08:33 PM Reply With Quote
wanna turbo the tiger dan? i never did ask you if you liked my car when you had a go that afternoon
iank
posted on 23/1/12 at 09:05 PM Reply With Quote
linkey no workey
http://gbszerobuild.blogspot.com/
Anonymous
chimney sweeper
posted on 23/1/12 at 09:46 PM Reply With Quote
Have to say I do not think the mileage is that high on this car 2 of my saabs have had more on the clock than this one was on 385,000 when I got rid of it and that was the same wngine as this.
May have to look at it for my project
If it isn't broken fix it till it is
hillbillyracer
posted on 23/1/12 at 11:15 PM Reply With Quote
All SAABs are front wheel drive, but it's the transverse engined ones that are useful for conversions unless you want to use the gearbox under engine set up from the classic 900 & 99.
The later ones with the GM floorpan means it'll bolt right into all sort of other GM stuff, like the mk3 Astra we have that has the 9-3 engine, box & running gear in now.
Our doner was a smashed 9-3 with 63k on the clock, £270.
£300 does in that respect seem expensive for a lot higher mileage but really it's a £300 car you drive & have a good play about with to make sure you're happy with the engine, sell what you can & weigh the rest in to recover a bit back. So you'd be looking at an easy 200bhp engine for under £200, how cheap could anyone ask for?!
ashg
posted on 23/1/12 at 11:41 PM Reply With Quote
Everything can always be cheaper. I'm a tight git if someone gave me something for nothing I would still try and haggle for more of a discount
hillbillyracer
posted on 23/1/12 at 11:51 PM Reply With Quote
Fair play, as an agric engineer & farmer's son I've seen this in practice!
contaminated
posted on 24/1/12 at 09:50 AM Reply With Quote
I've been thinking about it ever since! I still owe you lunch for sorting my brakes as I recall!
ashg
posted on 24/1/12 at 01:13 PM Reply With Quote
i think before you go down the turbo road you should fit throttle bodies and a proper ecu. that will drag you in to the modern world.
contaminated
posted on 24/1/12 at 02:32 PM Reply With Quote
Pah! When I was a teenager all I wanted was a car with twin 45s. Not getting rid of them now I have them
ashg
posted on 24/1/12 at 03:42 PM Reply With Quote
back in the 1800's i suppose 45's were the coolest things on the block
