Author: Subject: Length od Sierra driveshafts - do they need modifying
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
Building: Haynes roaster in college with students, gulp!
posted on 5/2/12 at 09:22 PM Reply With Quote
I have seen a guy on ebay who is selling rear wishbones that are 10mm longer than the book so that standard sierra driveshafts can be used. What is he on about, do I need to shorten my driveshafts if I build it to book spec. I am using the bolt on type of shaft if that helps.
[Edited on 5/2/12 by sg_frost]
daniel mason
posted on 5/2/12 at 09:27 PM Reply With Quote
plenty of movement on cv joint of a drive shaft. youll get 10mm each way no problem. dont worry
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
posted on 5/2/12 at 09:28 PM Reply With Quote
Thank you, will get on and make them then.
AdrianH
posted on 5/2/12 at 09:31 PM Reply With Quote
Which book are you working from, if the Haynes roadster, are you using the 2nd edition of the book as there was a mod to use the longer shafts?
Adrian
Edit note from pictures you are doing own chassis,
[Edited on 5-2-12 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
posted on 5/2/12 at 09:34 PM Reply With Quote
Book was bought last summer some time, not a clue which edition it is but it is the haynes roadster. The book is on the desk in work, the benefits of working in a motor vehicle college
That chassis in the pictures of roundtube went years ago, building a book spec one to my specs!
AdrianH
posted on 5/2/12 at 09:56 PM Reply With Quote
Have a look at these amendments to the book. Thought they were included in later prints, could be wrong.
http://www.haynes.co.uk/forums/showthread.php?t=2430
Adrian
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
posted on 5/2/12 at 10:37 PM Reply With Quote
They would have helped on the front frame, thanks for the info, will check the book to see.
snapper
posted on 6/2/12 at 07:15 AM Reply With Quote
The first book had errors one of which was the rear wishbones and or frame width.
The 10mm longer wishbones solved the problem
May not be relevant now but worth a check.
Haynes roadster forum would be the best place to ask specifics
I eat to survive
I drink to forget
