LancasterBob
posted on 14/2/12 at 02:51 PM |
Sierra 7" diff, clear out + free stuff
Moved house, and new one leaks more than the fury hood, so time to raise funds for repair! All parts can be posted at cost, or picked up / dropped off
in Macclesfield, Runcorn, north Dorset or somewhere between.
1) 7" 3.62 Sierra diff, takes push-in shafts. Used for circa 250 miles including IVA (no idea what it did in the sierra before that) with no
probs or whining. Comes with free assembly jig to hold it in the right place to get the bolts in on a Fury, so has a couple of blind 8mm holes on
non-stressed parts of casing (see pics) and 3 x M4 tapped holes on nose to position speedo sensor near prop bolts.
[url=http://www.flickr.com/photos/96661824@N00/6874938359/]
£80 ono?
2) 122.5mm diameter round Hella fog lamp, boxed. rrp £16 from SVC, £8?
3) Auto carpet, 2 large black sheets at 190cm x 150cm, from Coverdale in Wigan. I'd guess its Blenheim black, got a bit carried away buying
pre-IVA. Covers all sorts and mysteriously falls out after IVA. £10 each, or both for £15.
4) Long wheel studs, 40 splines, 63mm overall length, 12mm x 1.5 so Ford or Vx. Qty 18. £10?
5) Decibel inserts to quieten exhausts down, 2.5" dia, part number JETU936330 from DT. 2 used, £14 RRP each, £5 each?
6) Escort handbrake lever from Rally design, brand new, part number RD6901, RRP £16, £8? Comes with free cable + linkage/rod to suit escort axle
(used).
Free to a good home:
Haynes manual for Chevette - no use to me as the locost is long gone but might be useful for Leader / star owners?
Entire 9" rear drum assemblies for sierra axle, new cyls + shoes from memory. Replaced with 8" so surplus.
90 deg mandrel bend 2.5" dia, slight surface rust, easy clean up.
9" Sierra rear drum brake shoes. and some 10" also. New.
MkII escort steering wheel. Round, large, energy absorbing boss, brown.
Cheerio,
Rob
(rob_j_hopkins@hotmail.com, 07812 157227)
loggyboy
posted on 14/2/12 at 03:20 PM |
Interested in the 9" drum parts - just the new bits if they can be posted?
Chippy
posted on 14/2/12 at 04:38 PM |
Interested in item 4, if you are willing to post? 4) Long wheel studs, 40 splines, 63mm overall length, 12mm x 1.5 so Ford or Vx. Qty 18. £10?
Regards Ray
LancasterBob
posted on 14/2/12 at 07:09 PM |
Loggy + Ray, U2Us sent....
Jamster1233
posted on 17/2/12 at 10:29 PM |
u have a prop
stuart collins
posted on 18/2/12 at 07:37 AM |
Can i have the 2.5" 90 degree bend..... u2u sent....
PSpirine
posted on 18/2/12 at 09:33 AM |
Interested in the steering wheel, any chance of a pic? Also, what diameter is it?
Ta,
Pavel
LancasterBob
posted on 19/2/12 at 12:17 AM |
Jamster: No prop I'm afraid, sorry.
Stuart: No probs, U2U sent.
Pavel: It's escort original, circa 14" dia, energy absorbing boss (as required for IVA), horrible brown vinyl finish. Can do a pic on
tues, but it's not exactly a thing of beauty ;0)
Cheerio,
Rob
