Author: Subject: ZX6R Carbs - Coming off manifold
davidimurray
posted on 18/2/12 at 10:38 PM Reply With Quote
I've got some ZX6r carbs on my car. These are fitted to a tubular aluminium manifold with silicone hoses. I noticed today that I got some popping back through the carbs and on investigation I have found that carbs 3 and 4 seem to be pulling out of the silicone hose (which itself doesn't look very happy!)
I've got stay bars on the bottom of the carbs to stop them popping off but they obviously aren't working so I'm looking at how to actually secure the 'rubbers' themselves.
Has anyone used the actual rubbers from a ZX6r but cut the flange off?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
lewis
posted on 18/2/12 at 11:18 PM Reply With Quote
I had the same problem try some rough wet & dry around the manifold to gave the silicone something to grip failing that weld a lip around the tip of each tube to stop them pulling off much like a colant pipe flange.
I am a driving god!..........sort of
snapper
posted on 19/2/12 at 08:29 AM Reply With Quote
Silicon is not fuel resistant unless it's the fluro lined stuff.
A raised bead or a wide groove for the clip to pull into might help.
I eat to survive
I drink to forget
whitestu
posted on 19/2/12 at 09:20 AM Reply With Quote
I use them without the flange cut off and have had no issues with them coming off. I should think you could cut the flange off and make this work assuming the manifold external size is the same as the rubbers internal size.
If you need measurements of the carb rubbers let me know.
Stu
Andi
posted on 19/2/12 at 09:51 AM Reply With Quote
gpz900r rubbers fit perfectly ..No flange bits either.
They are on ebay but a bike breaker should do them for a lot less
Andi
davidimurray
posted on 19/2/12 at 09:54 AM Reply With Quote
Hi guys
Sorry I should probably have made myself clearer. The silicone is not pulling off the tube - I put a lip around the tubes with a beading tool. THe problem I have is the actual carbs themselves pulling out of the silicone tubing.
Stu, do you just have a clamp (jubilee clip) around the carb end and enother around the tube down by the flange ?
Dave
whitestu
posted on 19/2/12 at 11:01 AM Reply With Quote
I just used the ZX6R rubber as Kawasaki intended so a jubilee clip at the carb end and bolted to the manifold like this:
Stu
macc man
posted on 19/2/12 at 11:46 AM Reply With Quote
I had this problem and fitted stay bars and a dab of super glue on each side. Solved the problem.
