coyoteboy
posted on 22/2/12 at 02:15 AM |
Audi parts questions - anyone with experience
Wondering if there's any info anywhere about Audi driveshafts. I've got some A6 shafts from the C4 chassis and I want to use the C5
hub/bearing arrangement to bolt to my own upright (nice bolt-on/bolt-off solution) as the C4 arrangement is bearings in upright. Problem is I
can't seem to find info on the shaft dimensions and identify if they'll fit or if I'll have to use the later model shafts to match.
I think the gearbox end is identical on all of them so that shouldn't be a problem, just an extra cost I didn't need
Anyone in the know with Audi parts or have immediate access to them? I may end up buying a hub/bearing assy and just giving it a go but it's a
waste of £35 if it fails.
chris-g
posted on 22/2/12 at 09:26 AM |
If you have a local GSF, Euro Car Parts or Audi dealer with a parts department then I would give them a try. They might have them in stock so you can
examine them or they can get the details/diagrams up on the computer. Failing I would post the question on one of the Audi forums, there seems to be
some knowledgeable people on them. If you can get hold of a copy of ETKA (VW/Audi parts software) or ELSAWin (VW/Audi service manual software) they
could be useful. Good luck.
rachaeljf
posted on 22/2/12 at 10:10 AM |
I think he's already asked on the Audi forums. Sadly one guy who might have been able to help passed away suddenly a couple of weeks ago (RIP
Jon).
Driveshafts and bearings do tend to be standardised, but that doesn't help much. To make matters worse, there are different shaft sizes and hub
arrangements within the C4 range.
Coyote, I have both C4 and C5 cars you are welcome to come and examine if that helps!
Cheers R
PS, is your mid engine monster Rorty based or your own design?
[Edited on 22/2/12 by rachaeljf]
coyoteboy
posted on 22/2/12 at 11:34 AM |
Indeed I spotted the post about Jon as I was writing my request to folks, such a shame when a nice guy like that is lost.
Hmmm I didn't know there were different shaft sizes within the C4 range, the adverts I've seen for shafts suggest the same ones fit from
the 1.8 petrol up to the 2.5TDI. That's going to confuse me.
I've been to my local ECP and they're not overly open to prospective requests like that - they're very much no-nonsense folks!
I'd love to come and look but I suspect you'd dislike me stripping your hubs?
My middy will be fully scratch designed and built around the ABZ engine and 01E 6spd box. I've been putting together suspension basics but
I'm trying to narrow down some of the standard parts I can use to keep some of the costs down. I'll be fabbing the uprights hence nice
bolt-on C5 bearing housings will be a big benefit.
I'll see if I can find a copy of ETKA or ELSAWin but I suspect that might take some illegal digging!
[Edited on 22/2/12 by coyoteboy]
daviep
posted on 22/2/12 at 11:41 AM |
Part numbers for the shafts are all different across the two ranges
However the wheel drive flange part# 4A0 407 615G is used on all models So that should be OK
Gearbox flanges come in 2 sizes 108mm and 130mm, both sizes are used on both models. So it looks like you have a 50/50 chance of having shafts which
will do the job.
HTH
Davie
coyoteboy
posted on 22/2/12 at 11:44 AM |
Hi Daviep,
Thanks for that! I'm amazed they use the same flange on all models - that's pretty spectacularly good commonality for an OEM I've
got the shafts off the box I have so I know that end fits, I just hope the length of the outboard that end fits through the bearings correctly is the
same on both. If it's a bit longer I could fairly comfortably make a spacer I guess!
rachaeljf
posted on 22/2/12 at 11:50 AM |
Good info from Daviep^^
Ach, too slow again.
You might find some dimensional info on the Chinese supplier sites, I often use Yiparts to look for modern bits to replace obsolete bits.
Slimy38
posted on 22/2/12 at 06:47 PM |
If you want to get hold of Audi part numbers, you can find the whole VAG range (up to 2005 ish) at www.vagcat.com. Sign up to the forums and you can
get into the online parts catalogue, which is the equivalent of ETKA.
Bear in mind that the hosting isn't the best so it can sometimes be unreliable, but for VAG details it's difficult to beat.
coyoteboy
posted on 27/2/12 at 02:08 PM |
No dimensional info available that I can find unfortunately. Looks like I'm going to have to buy one and see if it fits, measure and go from
there! There's some nice smaller ones on the A3s but they're no cheaper so barring a few hundred grammes it's not worth the
unknown.
Cheers all
