Author: Subject: Brake lines and loom together
supercat
posted on 27/2/12 at 02:51 PM Reply With Quote
I am using rivet on cable tie bases and wondering if it is ok to secure brake lines and the loom in the same base/tie. I am assuming its ok as long as they are secure and cannot rub against anything?
The fuel lines are seperate with rubber lined p-clips.
Thanks,
James
posted on 27/2/12 at 03:00 PM Reply With Quote
Not sure if it would be a specific IVA fail, but I wouldn't do it myself. Far rather use rivet on plastic P clips (Maplin, RS etc) or plastic push-in C shaped pipe clips (Vehicle Wiring Products) for the brake pipes.
posted on 27/2/12 at 03:02 PM Reply With Quote
posted on 27/2/12 at 05:35 PM Reply With Quote
Never clip anything to a brake or fuel pipe, and always ensure nothing rubs against or touches a brake pipe.
These are the most suitable type easy and quick to use should be able to get them from any motor factors.
Dax Kit Car Brake Pipe Clips (10) | eBay
