Author: Subject: RE-Pinto Set up
Tinks1
posted on 1/3/12 at 12:50 PM Reply With Quote
RE-Pinto Set up
Hi Guy's
Following on from my post earlier regarding the "TAK TAK" noise on further investigation I have
tracked it down to Cylinder No1, more luck than management, I have found that if I remove the
No1 plug lead the "TAK TAK" noise disappears, I have tried with all the other pots and this makes
no difference, I have changed the plug leads and spark plugs, and only by removing the no1 lead
does the noise disappear.
Any help appreciated
John
Daddylonglegs
posted on 1/3/12 at 02:56 PM Reply With Quote
Little Ends possibly? No firing means no load on the little end.
That's my 2p worth
snapper
posted on 1/3/12 at 04:04 PM Reply With Quote
Exhaust leak at the manifold face often sounds like a Tak Tak.
I eat to survive
I drink to forget
mark chandler
posted on 1/3/12 at 07:11 PM Reply With Quote
I,m still with the follower retaining spring, have you looked at this ?
Tinks1
posted on 2/3/12 at 12:49 PM Reply With Quote
Thanks for your responses .... It was a cracked exhaust gasket, relaced all OK
