Author: Subject: applying for iva
steve8274
posted on 10/3/12 at 03:14 PM Reply With Quote
applying for iva
hello all
not far off completion now so looking to apply for my iva
i have filled in my forms (iva and amatuer build up)
as well as filling this in, i believe you send some receipts and photos
how many are required and is there anything in particular which must be shown or just various stages of build
do you have to sign any of the photos or receipts? cant remember if i have read this somewhere.
lastly, does anyone know the max speed for a 1.8cvh for iva form. only bit of info i cant find in book
thanks
steve
deezee
posted on 10/3/12 at 03:33 PM Reply With Quote
Your maximum speed needs to be under the speed rating of your tyres and a little realistic. So 120 mph would be OK. You going to Chadderton for the test? The receipts are just to prove you've bought stuff for the amateur build evidence and to demonstrate that some components are genunine fuel / brake fluid safe, if not otherwise marked. The guy there likes to see various stages of the build in photos, as to demonstrate you've made the car and also details he can't see during inspection. For me that included seatbelt mounting points that and hidden and photos of where I'd used loctite on important bolts, if they didn't have nylocs!
I sent through nearly everything I had with my application. It must have been an inch thick pile of paperwork. I didn't sign anything.
[Edited on 10/3/12 by deezee]
Gus
posted on 10/3/12 at 07:51 PM Reply With Quote
Hi, my car was IVA october 10.All I sent was 6 photo's of the build, and photo copies of the main reciepts [steel, shocks, donor, body work].Then took all my photo's and reciepts along on the day of the test . All he looked at was the V5 and the photo's of the bottom harness mounts.
steve8274
posted on 11/3/12 at 10:56 PM Reply With Quote
ok
thanks for the help. might just copy all receipts and send photo cd to be safe. take all originals with me on the day
deezee, yes i will be booking in for chadderton. did you do yours there? good experience
another query
when i send off paperwork, i need to send
IVA1
amateur build declaration (IVA4)
do i need to send built up vehicle inspection report (V627/1) or is this for dvla afterwards for registration
thank you
steve
BobM
posted on 12/3/12 at 06:46 AM Reply With Quote
Originally posted by steve8274
another query
IVA1
The V627/1 is for DVLA at registration time.
Not very Locost but very BEC
