Author: Subject: Which fuel pump?
wombat
posted on 17/3/12 at 09:01 AM Reply With Quote
Which fuel pump?
Morning, had a few days off work and managed to get quite a lot done (despite missus nagging about cutting tree down and gardening....did niether!).
I have run a feed and return for the fuel, and now need to fit a fuel pump before I can finish off the rear end.
Question is what pump to buy?
I have a 2.0 Silvertop + GSXR600 TBs and will run MS2, no plans for big bhp (budget restrictive).
Advice please
big_wasa
posted on 17/3/12 at 09:29 AM Reply With Quote
I use the bassic universal Bosch Fuel Pump 0580464070 ALFA,FIAT,LANCIA,JAG KIT CAR universal brand new | eBay pumps. They give plenty of fuel on a standard engine. If going for more power I would look for a better quality pump.
maccmike
posted on 17/3/12 at 09:37 AM Reply With Quote
Iv got a facet fuel pump available?
think its 3.5-5bar without looking
although having said that, do you need bike pump to go with tb's?
[Edited on 17/3/12 by maccmike]
wombat
posted on 17/3/12 at 10:33 AM Reply With Quote
Maccmike, not sure now ! Thought I was ok with car pump and return.
Sure someone on here running same engine /TB set up will give their words of wisdom..........
Folks???
L5W
posted on 17/3/12 at 10:38 AM Reply With Quote
Hi, I have the same set up and I'm using a fuel pump which looks very similar to the one big_wasa posted.
BRAND NEW Electric Fuel Pump BMW 318 320 323 325 520 | eBay is the one I bought a while back from the same ebay seller
cheers,
Lee
http://l5w-mk-indy-zetec.blogspot.com/
big_wasa
posted on 17/3/12 at 12:55 PM Reply With Quote
Yep same thing, infact the blue one is the same as mine.
You dont need a bike pump for bike Itb's They use bike pumps for bike carbs as its a cheap way of giving <2psi pressure to the carbs and more reliable than regulators.
Any high pressure pump will be fine. The regulator controles the pressure at the injector not the pump.
You just need to make sure it has enough flow.
Ive pulled pumps out of a mondeo and submerged them in a tin of petrol for a bench test ...
[Edited on 17/3/12 by big_wasa]
wombat
posted on 17/3/12 at 01:20 PM Reply With Quote
Filter
I am thinking of having a filter between tank and pump, then another in the engine bay before rail.
Is this correct and if so, which type to get?
Ta so far.
Will post some pictures tomorrow...
big_wasa
posted on 17/3/12 at 01:32 PM Reply With Quote
Yes a good idea to have filters before the pump. There is all sorts of sediment in the fuel.
I just found somthing in halfords or ebay with suitable connections.
Is your tank baffled or sumped ? If not I would think about a swirl pot for fast road and track.
L5W
posted on 17/3/12 at 02:56 PM Reply With Quote
Hi. thats how its set up on mine.
I found a sytec fuel filter on ebay which had the 12mm hose connection I needed to match the outlet on the tank sump and pump hose inlet. I'm using this as a pre-pump filter, couple of pics of how I mounted it here (Ignore the braided hose, I've changed this for some better stuff)
I think FUEL INJECTION PUMP FILTER CATERHAM 7 WESTFIELD DAX | eBay is the filter I'm using, bit pricey but I was struggling to find one with 12mm connections anywhere else.
Lee
ali f27
posted on 17/3/12 at 05:05 PM Reply With Quote
McGill motorsport best price used them on a number of cars spot on
wombat
posted on 18/3/12 at 10:04 AM Reply With Quote
Thx guys, more shopping this week then..
Wasa, not got tank yet so both options still open.
