adrianreeve
posted on 17/3/12 at 05:08 PM |
What tyre pressures do you recommend?
Hi guys, just wondering what tyre pressures you run? If it helps, it's a Haynes roadster, with a zetec engine and 195/50/15 tyres, mainly road
use.
Adrian
steve m
posted on 17/3/12 at 05:21 PM |
mine are 16psi 205/55/13 all four of them
Madinventions
posted on 17/3/12 at 05:25 PM |
I've got 195/50/R15 with 520kg total weight, and I run about 15psi (when cold) all round.
Ed.
View my band website:
http://www.shadowlight.org.uk
perksy
205/60 x 13 16 psi
Tried 20 psi once as an experiment and it was horrible
Stott
posted on 17/3/12 at 05:38 PM |
195 50 15 Bec 446kg
18 front 20 rear normally, tried 16/18 at llandow on sat and they werent warming up properly
dunk3
posted on 17/3/12 at 05:55 PM |
I am running 205/50/15 with a Zetec , and i run 18psi all round
lotusmadandy
posted on 17/3/12 at 08:21 PM |
^^Mine are the same as dunk's^^
Gus
posted on 17/3/12 at 08:38 PM |
Running 195/50/15 with zetec in a Haynes Roadster, tyre pressure is 18psi all round.
Gus
Not Anumber
posted on 26/5/12 at 10:08 AM |
Still experimenting. I'm currently on 18psi front, 20 rear. 195/50/R15 MK Indy, Pinto, Type 9, Protech coil overs shocks etc
When i first tried driving the car after the front end rebuild it was truly awful. Talk about streering that didnt centre - this baby took twice as
much effort to return the wheel to centre than to steer away from it plus the suspension felt rock hard and i knew it hadn't been setup that
way. I really wondered what on earth could be so far out and started looking at camber, caster and toe in - whilst what i should have done was just
check the tyre pressures first.
Clearly tyre centres dont seem to know whats normal for lightweight cars.
The O/s front was the only tyre near right as this was the only one that hadn't been touched. The others had all been reseated or replaced and
were between 35 psi and 38psi. Dropping the pressures instantly made the car tractable and pleasant to drive.
Could there be a further improvement by dropping the pressures down to 15psi all round with this setup or is that mainly for BECs ?
