Author: Subject: 2.0 Zetec flywheel. (not the common question)
ahunt
posted on 28/3/12 at 03:43 PM Reply With Quote
Good dayyyy.
Yet another question i need help with. Rather than strip the engine back out of the car to find out orr cost me 60 odd quid. Does or would anyone know what the PCD of the holes for the clutch plate on the 2.0 silvertop flywheel is? The flywheel i have is the 240mm clutch type not the 220. Ive got the 1.8 flywheel here and the PCD for those 6 holes are 242. Ive looked around the net but havnt mangaged to find an answer.
Taaaa muchly
Car 90% complete!!!
ChrisL
posted on 28/3/12 at 06:25 PM Reply With Quote
Silver top / blacktop 1.8 2.0 (and1.6 I think) have the same bolt pattern. It's not regular as its used to key the flywheel to the crankshaft
HTH
Chris
Edit - Didn't read the post correctly, the clutches are different.
[Edited on 28/3/12 by ChrisL]
posted on 28/3/12 at 07:33 PM Reply With Quote
Clutches are different between the 1.8 and 2.0.
1.8 flywheel is flat whereas the clutch on the 2.0 sits in a recess as the 2L flywheel has a raised section round the edge where the bolts are lifted off the face of the clutch.
They aint interchangeable.
