Author: Subject: Xflow Alternator on 4AGe, maybe a problem...
nib1980
posted on 2/4/12 at 09:35 AM Reply With Quote
HI All,
I'm just preping the kit for her yearly MOT and summer driving.
fitted a new battery (increased cranking amps)
started no hassel, did a little check, and the reading when running at idle was only 12.8V across the battery. i'd expected 14.2v....
SETUP:
toyota 4age engine.
Xflow Alternator (lucas type)
Alternator has had the pully from the toyota alternator put on it.
SO:
is the problem,
1) knackered regulator? is there a test and where do i get a new one
2) Knackered alternator maybe from over revving of the alternator (pulley sizes)?
3) Actually no problem and i'm being daft
4) Other?
simple votl meter checks and quick cheap solutions appriciated
Many thanks
nib1980
posted on 2/4/12 at 11:31 AM Reply With Quote
no one about today?
russbost
posted on 2/4/12 at 12:18 PM Reply With Quote
You should have around 14.5 volts with engine revs at around 2000rpm & dipped beam on - no other electrics, if battery voltage is not rising from the 12.8 you say you've got then alternator isn't charging.
You're saying Xflow Lucas alternator, so I'm guessing Lucas 17 ACR, IIRC the rectifier is soldered in & is part of the control unit, no particularly simple way of checking without pulling the back off & doing some meter checks to see what you've actually got b4 the control/rectifier. B4 doing that I would check that you have a good supply to the main large Lucar terminals on the alternator, the favourite with these was that the plug became a bit loose & overheated due to the current it transmits, if the terminals look at all burnt, then you need to fit a new plug b4 doing anything with the alternator or it will just repeat fail.
They used to be dirt cheap & it wasn't really worth faffing with internals better just to go for a replacement unit, don't know what sort of money they are nowadays?
nib1980
posted on 2/4/12 at 12:22 PM Reply With Quote
hmm, to be frank that was my feeling and new alternator is abotu £40, so not money breaking.
it's located untder the exhaust too, so maybe need to check this over heating and dirt first.
think i have a spare actually in the shed, might just give it a whizz first.
is it possible it's over revved and burnt out?
russbost
posted on 2/4/12 at 12:38 PM Reply With Quote
The Toyota is a lot higher revving than the Kent, I would have thought the pulley ratios weren't dissimilar, but seem to remember race Xflows revving to about 10,000 rpm & I think they ran standard alternators? I would think you have to be holding high revs for long periods to damage the alternator & even then I'd be expecting thrown coils rather than burnt out. All IMHO of course!
nib1980
posted on 2/4/12 at 12:56 PM Reply With Quote
good oh, think i'll just get a new alternator then if i haven't got one already.
happy days, simple fix
posted on 2/4/12 at 12:58 PM Reply With Quote
In the old days with hot Xflos the standard crank pulley was swapped for a smaller dia cast pulley which was usually called the Lotus Twincam pulley but I think was actually an Anglia 105e part.
Back to the alternator most likely worn brushes ---- very very simple to change if the slip rings aren't worn out. Changing the slip ring requires simple soldering (nothing fiddly), the regulator is also easy to change but changing the diodes is best left to somebody used to soldering.
If the alternator diodes are knackered would sugest swaping the alternator for the later Lucas Magneti Marelli a127 which is more modern and a straight swap just make sure you get one with the correct pulley as the pulley to shaft fitting is different.
[Edited on 2/4/12 by britishtrident]
nib1980
posted on 2/4/12 at 01:23 PM Reply With Quote
would that be a straight swap or need a connector change?
posted on 2/4/12 at 03:15 PM Reply With Quote
Standard 3 blade same as older ACR just make sure you get one handed the same way and correct pulley.
ACR alternators you can change from left to right handed --- never tried on the A127 but should be ok.
posted on 2/4/12 at 06:22 PM Reply With Quote
Might be worth fitting a heatshield between the exhaust and the alternator . My car went through a couple of alternators before fitting a heatshield, since fitting one it's been fine
nib1980
posted on 2/4/12 at 07:07 PM Reply With Quote
well been out and tested again,
no change at idle or when revved.
infact no different even if the alternator wasn't connected.
my conclusion is something very wrong in teh alternator, so i'll order a new one, unless anyone has any suggestions.......
nib1980
posted on 2/4/12 at 08:25 PM Reply With Quote
think i may have found the problem.......
nib1980
posted on 5/4/12 at 03:01 PM Reply With Quote
well chencged bushes made no diference, so wondering what it muight be now.
dammit i'm not good on electrics ND WANTED IT ON THE ROAD AGAIN.
dam caps lock key
tul214
posted on 5/4/12 at 03:12 PM Reply With Quote
I used a Suzuki Vitara alternator and hung it from the inlet side;
Alt sm
Alt sm
1.6 Raw Super6 sold
Dopdog
posted on 7/4/12 at 08:58 AM Reply With Quote
are you sure the wiring is correct? I had this issue and it turned out I needed a positive feed to the alternator as well, just a small link from the battery connector to the next pin
