Author: Subject: Nipple help, I need larger ones
Antnicuk
posted on 12/4/12 at 08:10 PM Reply With Quote
One of my bleed nipples snapped today. I have drilled out the remains as it would not budge. The nipple was a 10mm x 1. I want to drill the whole bigger and re tap it for a larger nipple but i cant find anything bigger than 10x1.
Any suggestions?
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
Wheels244
posted on 12/4/12 at 08:24 PM Reply With Quote
What about Helicoiling ?
So long as you haven't gone too big when drilling the old one out , it should be OK.
Antnicuk
posted on 12/4/12 at 08:26 PM Reply With Quote
not tried helicoils before, will it seal ok?
Stott
posted on 12/4/12 at 08:32 PM Reply With Quote
It's not the thread that seals the fluid it's the nipple seating in the calliper so it doesn't matter.
HTH
Stott
Wheels244
posted on 12/4/12 at 08:34 PM Reply With Quote
Yes, should be fine.
I've had calipers done before and sealed fine.
The kits are quite expensive to buy, but any decent engineering place should have the kit.
MachineMart do the kits but I don't know how good their quality is.
gremlin1234
posted on 12/4/12 at 08:37 PM Reply With Quote
broken brake bleed nipple repair kit
http://www.tssc.org.uk/index.php?option=com_fireboard&Itemid=55&func=view&id=69917&catid=219
and:
http://www.youtube.com/watch?v=q0Q_5F1o_wY
[Edited on 12/4/12 by gremlin1234]
Wheels244
posted on 12/4/12 at 08:40 PM Reply With Quote
Actually the price is not too bad for a single size
http://www.machinemart.co.uk/shop/product/details/040216679#reviews
Wheels244
posted on 12/4/12 at 08:49 PM Reply With Quote
and:
I like that idea too - simple and effective.
Only potential drawback I can see is not having enough meat around the nipple to be able drill out to the larger size.
Antnicuk
posted on 12/4/12 at 08:53 PM Reply With Quote
thanks guys
the nipple therapy site doesnt seem to tell you what size the insert is and the helicoil kit doesnt say what pitch it is
Wheels244
posted on 12/4/12 at 08:59 PM Reply With Quote
What size was the nipple that sheared ?
Antnicuk
posted on 12/4/12 at 09:04 PM Reply With Quote
10x1, typically the biggest i can find
Wheels244
posted on 12/4/12 at 09:05 PM Reply With Quote
Sorry - re-read the post M10x1
Try this one
http://www.machinemart.co.uk/shop/product/details/armstrong-eco-kit-spark-plug-thread-repair-kit-3
Quite a bit more expensive though.
Engineering place might be your best bet - will only take 10 mins to do.
posted on 12/4/12 at 09:26 PM Reply With Quote
Hugely disappointing thread gents
Was really hoping for bigger nipples
Wheels244
posted on 12/4/12 at 09:28 PM Reply With Quote
posted on 12/4/12 at 09:36 PM Reply With Quote
http://www.agriemach.com/c34/tools-engine/p868-brake-bleeder-repair-kit.html
posted on 12/4/12 at 10:32 PM Reply With Quote
Cold water usually works
slingshot2000
posted on 12/4/12 at 11:22 PM Reply With Quote
Yes, I was expecting to find that the ranks of Locoster had a new member with the name Jordan !
