Author: Subject: To many steering UJ`s ?
w.olly
posted on 15/4/12 at 05:19 PM Reply With Quote
On building the steeering colum to the rack is there a max amount of UJ`s you can for the IVA, and certain regs involved?
Am i correct in thinkig the more UJ`s the more play there would be in the steering?
Wolly
jossey
posted on 15/4/12 at 05:47 PM Reply With Quote
Doesnt it depend on how tight the UJ joints are. my tiger has 1 extra UJ added to the current 1 UJ and rubber thing which is standard on the bottom of the column next to the rack.
I dont like the fact it has the extra UJ but its needed to get round the engine.
Make sure its mounted with a sphere bearing half way down to stop the movement.
[Edited on 15/4/12 by jossey]
David Johnson
metro6r4
posted on 15/4/12 at 06:06 PM Reply With Quote
dont know about maximum for the iva but the more uj's the more play
w.olly
posted on 15/4/12 at 06:08 PM Reply With Quote
Hi David, yes i guess thats correct in if they have no play, i hope you mean you have 1 extra UJ, not 12 as you said LOL
Cheers mate
wolly
blakep82
posted on 15/4/12 at 06:32 PM Reply With Quote
don't think theres a maximum, but more than two, and you'll need to support the column somewhere!
certainly can't think of any mention of a maximum number in the manual
________________________
jossey
posted on 15/4/12 at 06:34 PM Reply With Quote
Oh yes sorry 1 I've edited it now lol
David Johnson
Chippy
posted on 15/4/12 at 09:27 PM Reply With Quote
I have three, one on the end of the coumn, one on the rack and a third half way down to get around the exhaust. This did mean that I needed a bearing near the mid one to suport the column and this is in a housing welded to the chassis. HTH Ray
Edit to add photo showing the UJ's
[img] Engine in and bolted down.
[/img]
[Edited on 15-4-12 by Chippy]
Liam
posted on 16/4/12 at 03:38 PM Reply With Quote
I have four .
For every joint greater than 2 you need a support bearing/pillow block to support the column, preferably close as possible to the joints. There's no detectable play in mine. If all the joints were floppy and worn out it'd be a different matter.
