Author: Subject: exhaust cut out shield.
carlknight1982
posted on 18/4/12 at 10:43 AM Reply With Quote
im looking to get a stainless/shiny piece of steel to cover the edge of the cut out in my bonnet around my exhaust
Any idea of a place that can do this for me ?
Carl
Logic will get you from a A to B
Imagination will take you everywhere.
Not Anumber
posted on 18/4/12 at 11:28 AM Reply With Quote
Most people working with sheet metal should be able to do this for you. The toughest thing is marking it out prcisely for them to make the cuts in the right place.
Will you be fitting the plate to the bodywork with a large margin around the pipes for movement or tight fitting it to the pipes independant of the bodywork ?
chris_harris_
posted on 18/4/12 at 01:48 PM Reply With Quote
If you know what you want, and have access to cad then there is a chap on here who does water jet cutting of pretty much anything you want. Can't recall his name though, sorry.
Chris
Regards Chris
loggyboy
posted on 18/4/12 at 01:51 PM Reply With Quote
Chris
andyw7de
Chippy
posted on 18/4/12 at 03:48 PM Reply With Quote
I have emailed Andy drawings, with the measurements on, just done on plain paper. Never had to use CAD, and they arrived exactly as requested. HTH Ray
chris_harris_
posted on 18/4/12 at 09:00 PM Reply With Quote
That's good to know for future then. I have Only ever asked for round or square items as they are clearly easier to setup. will try a drawing next time then.
Chris
Regards Chris
