dan8400
posted on 18/4/12 at 01:36 PM |
Bought F/glass repair kit...no instructions. Any ideas?
as per title really. I have a hole in my bonnet (for air filter on pinto but since changed to zetec/bike carb). Was hoping to fill the hole with a
fibreglass repair kit, then bodyfiller the repaired hole and then going to wrap the car.
Can anyone walk me through the technique?
Dan
EDIT: The kit comes with matting, resin and hardner. It's mixing the resin/hardener that I am most worried about.
[Edited on 18/4/12 by dan8400]
Hey - That's Journey!!!
posted on 18/4/12 at 01:44 PM |
Have a look on CFS website for a how to. It depends on temperature and how quick you want to
do the job. If you want the repair fairly flat to add filler put some cellophane over the top of the bonnet hole and then put the matting on from the
back and stipple the resin into it. After it sets peel the film off the front.
[Edited on 18/4/12 by Peteff]
dan8400
posted on 18/4/12 at 01:46 PM |
Thanks Pete, will check that out
Dan
owelly
posted on 18/4/12 at 02:37 PM |
If its a fastglas type kit, aim to use a pea sized blob of hardener to an eggcup of resin, or about 2% if its easier to work out!
http://www.ppcmag.co.uk
owelly
posted on 18/4/12 at 02:40 PM |
http://www.google.co.uk/url?sa=t&source=web&cd=3&ved=0CDsQFjAC&url=http%3A%2F%2Fwww.qpaints.co.uk%2Fpdf%2FFASTGLAS-TDS-EN.pdf&ei=0
NGOT-f_I4el8gOMt7nFCw&usg=AFQjCNHqiBsXQU9TIJwt5F1jqcuT-TdT3A&sig2=Uyzw9r4Io-z3LGTvqiLm1g
trextr7monkey
posted on 18/4/12 at 03:06 PM |
Have a look on the East Coast Fibre glass site full of useful info
mark chandler
posted on 18/4/12 at 04:51 PM |
Span the hole with gaffer tape, then back fill with matting and resin having a good overlap.
I would also be inclined to cut some v's and inch deep around the hole, as it increases the contact area and spreads the join so you do not end
up with an obvious filled hole.
Macbeast
posted on 18/4/12 at 04:55 PM |
Put an air scoop / vent on it
