NickMK
posted on 19/4/12 at 05:42 PM |
Pinto cambelt cover studs
Hi, I want to fit a cambelt cover to my pinto but when i went to fit I realised I don't have the studs in the head to hold the cover.
Has anyone got these two studs? This isn't a photo of my car but a photo of the parts I need. Thanks. Nick
[Edited on 19/4/12 by NickMK]
omega0684
posted on 19/4/12 at 05:56 PM |
Alternative: Fit a floor panel?
JeffHs
posted on 19/4/12 at 07:20 PM |
IIRC those arrowed parts are threaded internally 6mm, so you use bolts.
dave r
posted on 19/4/12 at 07:28 PM |
if you havent got the rh one, the cam tensioner wont be working wither
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
NickMK
posted on 19/4/12 at 07:30 PM |
Yes they would be threaded internally. This isnt a photo of my car but a photo of the parts I need. I have the cam cover and the bolts that thread
in to those internally threaded studs.
NickMK
posted on 19/4/12 at 07:32 PM |
You don't need the spring for the tensioner. The spring is only used to set the initial tension before you do up the bolts and to be honest it
never really set the tension correctly
