Author: Subject: Water Methanol Injection advice
T66
posted on 26/4/12 at 08:29 PM Reply With Quote
My engine came with a Snow water methanol injection system, single nozzle spraying into the plenum. The header tank is below, but I am not sure why are there two tanks ? I would sooner use a smaller plastic tank.
They are not interconnected at all, and the smaller tank with two outlets has no drain. The systems I have read about generally use a plastic header style tank.
Reason I am installing it , I dont know how much the engine relies on this system to avoid detonation, so would sooner fit it and use it, than hole a piston, is the system likely to cause any issues at IVA time ?
cheers
metro6r4
posted on 26/4/12 at 08:39 PM Reply With Quote
i always thought plastic could be doselved by methanol
T66
posted on 26/4/12 at 08:43 PM Reply With Quote
The bits of reading Ive done, all the kits have a plastic bottle.
http://www.horsepowerfreaks.com/partdetails/Snow_Performance/Engine/Water-Methanol_Systems//18675
posted on 26/4/12 at 08:48 PM Reply With Quote
I don't think the second tank has anything to do with the water / methanol system Ivan.
I reckon the builder has just fabbed the 2 tanks together due to space 'issues'.
It's Evolution Baby!
T66
posted on 26/4/12 at 08:52 PM Reply With Quote
The small tank has me intrigued, as it has no drain and doesnt have any oil contamination. Dont think I will need the huge tank, so it will get swapped for a smaller easier to fit in plastic jobby.
Or I just cut the smaller tank off.
[Edited on 26/4/12 by T66]
posted on 26/4/12 at 08:55 PM Reply With Quote
Or just fit a small breather on one of the outlets and use it as your oil catch tank?
T66
posted on 26/4/12 at 09:12 PM Reply With Quote
It will meet Mr Dremmel in the morning, might even clean the thing up.
Is there anyone running a water/meth setup who has IVA their car ?
Autosri
posted on 26/4/12 at 10:23 PM Reply With Quote
methanol corrodes alluminium but doesnt touch plastic i just bought a small window washer bottle i think its 1.2litres but i only use it with my nitrous so dont use much
T66
posted on 27/4/12 at 05:15 AM Reply With Quote
I've got a golf expansion bottle which I fancied using.
Autosri
posted on 27/4/12 at 07:21 AM Reply With Quote
Long as it has a breather hole I guess it makes no odds what bottle you use
I found the aquamist nozzles to give the nicest spray pattern I use a 0.3 mm nozzle with a 130 psi pump
T66
posted on 27/4/12 at 02:36 PM Reply With Quote
The engine I believe was built for a hillclimber, but Im not so sure as the tank is huge. Doesnt seem much point in hauling 3 litres of water/meth for 90 seconds.
The pump will get plumbed in, but I will hold off buying a tank till I know what space is left.
cheers
Antnicuk
posted on 27/4/12 at 08:44 PM Reply With Quote
do you have a pump /kit? I have a full cooling mist kit thats had very little use. It comes with a plastic tank that is specifically designed to accept the pump so you get the maximum space saving. I am looking for £250 as it has everything you need and although fitted to my kit car for about a year i never ran enough boost to activate it. Its basically like this but the tanks is the same one
http://www.coolingmist.com/pagedisplay.aspx?pid=ShurTank
http://www.coolingmist.com/pagedisplay.aspx?pid=250psidieselkit&feature_key=Diesel
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
T66
posted on 28/4/12 at 08:56 AM Reply With Quote
Thanks Ant.
Yes I have the pump and related controller, Good offer though thank you.
