Author: Subject: Calling all Tiger avon owners using sierra uprights
jossey
posted on 1/5/12 at 05:48 PM Reply With Quote
As above anyone using sierra front uprights on your Avon?
I'm wanting to use sierra as I have decent calipers and drilled grooved discs but I see the book says big changes need to be made.....
David Johnson
Rudy
posted on 10/5/12 at 10:42 AM Reply With Quote
Hi, I used it and I meet some problem. This is what i did http://www.locostbuilders.co.uk/viewthread.php?tid=53010&page=1 , you have to pay a lot of attention to have a good steering response.
Hope that help
Ciao Rudy
Sorry about my English
Minicooper
posted on 10/5/12 at 11:47 AM Reply With Quote
The tiger avon book when referring to sierra uprights also uses the sierra lower arm setup this means significant changes to the chassis and suspension brackets. If you use just the sierra upright you can fairly easily mount it to what you have as standard on the front of an avon like Rudy.
When I was trying to make my mind up between sierra and cortina uprights I just swapped between them as I changed my mind, from memory I believe the upper wishbone needs to be a little shorter when using the sierra upright, but it looks okay on Rudy pictures so maybe I don't have a good a memory as I thought.
The wishbone setup I used was the Haynes roadster, the upper wishbone on the Haynes setup is much lower down, so you don't need the elevated muchroom adapter pictured on Rudy's upright
laptoprob
posted on 10/5/12 at 03:36 PM Reply With Quote
Dave your just a glutten for it ....
Be like the rest of us and go for the glorious Cortina upright and sell the discs etc you have in favour of the mighty M16 calipers
jossey
posted on 4/6/12 at 03:55 PM Reply With Quote
I don't like easy lol
Dave
David Johnson
jossey
posted on 4/6/12 at 03:56 PM Reply With Quote
Thank you all :-) ill give it a go :-)
David Johnson
