roohunter
posted on 7/5/12 at 08:30 PM |
mk indy engine height help needed!
Hi Folks
I need your help again folks,i have aquired a 80% built Indy with a Zetec black top in
it,it has the 2 peice sump on it on to a MT75 box.The sump and bell housing are about 3/4 inches below the level of the floor.
1,, is this normal and if not what do i need to do, thanks folks
austin man
posted on 7/5/12 at 08:44 PM |
I have the silvertop in mine the sump is around 3 1/2" from the floor gearboc is a type niine and sits below floor level so sounds about right
RK
posted on 8/5/12 at 03:28 AM |
But avoid bumpy roads. I fried my engine hitting something, losing oil and pressure.
lotusmadandy
posted on 8/5/12 at 06:05 AM |
My indy has a blacktop and is about
the same.As said,go easy over the speed bumps.
