Author: Subject: rear lights
accident
posted on 31/8/04 at 11:56 PM Reply With Quote
rear lights
what are the legal height and spacing issues for the rear lights on a locost?
stephen_gusterson
posted on 1/9/04 at 08:55 AM Reply With Quote
another person that needs an sva manual
from memory
must be no more than 400mm from the outside edge of the car (measured to edge of lit lens are)
Must be at least 350mm from ground
must be at least 400mm apart across car.
atb
steve
kingr
posted on 1/9/04 at 12:03 PM Reply With Quote
That sounds about right SG, the vertical heights are measured to the lowest point, the horizontal distances are measured to the outermost edge.
Kingr
john_p_b
posted on 2/9/04 at 07:28 PM Reply With Quote
quoted straight outta the SVA book in front of me on my desk........
max distance from side = 400mm with a minimum seperation of 500mm unless vehicle width is less than 1400mm then minimum seperation is 400mm
minimum height = 350mm
maximum height = 1500mm (not that it's ever gonna be a issue on a locost!)
