Murphy
posted on 10/5/12 at 05:29 PM |
Replacing a tie rod
In relation to the "how to remove a tie rod"
Specifically the pin that needs drilled out to release.
Is there a special pin that needs put back in or will an appropriate sized metal pin type item suffice if secured in the hole?
Thanks in advance everyone
austin man
posted on 10/5/12 at 07:19 PM |
a split pin is the usual pin, the pin should also pull out if not drill it nice and slowly
posted on 10/5/12 at 07:59 PM |
The Mk2 Escort racks normally have a soft metal pin to secure the inner ball joint to the end of the rack, which has to be drilled out. I'd
have expected a new pin to come with the rack end to be honest.
posted on 10/5/12 at 08:14 PM |
It's a pair of used tie-rods that came from an old rack of mine (so the old pins are now in pieces). They were indeed a pretty soft metal (not
split-pins).
It's Evolution Baby!
