Author: Subject: Solidly mounted engine
kango
posted on 20/5/12 at 03:36 PM Reply With Quote
Any problem in mounting a engine solidly? This is for a pure race car!
Set up is a rear engin / gearbox transversely mounted.
wylliezx9r
posted on 20/5/12 at 05:23 PM Reply With Quote
My bike engine is mounted solidly with no problems, not sure what a car engine would be like though.
George Best
austin man
posted on 20/5/12 at 05:59 PM Reply With Quote
I reckon you will shake ya fillings loose can you not fit uprated engine rubbers ? all the vibrations will travel through the chasis> I would imagine this would also be felt through the sterring wheel
lsdweb
posted on 20/5/12 at 06:16 PM Reply With Quote
My Locost was solid mounted - 1300 Crossflow then 2 litre Zetec - no problems.
zilspeed
posted on 20/5/12 at 06:22 PM Reply With Quote
It'll certainly cause long term issues with those components which are lightly secured such as bodywork.
It'll fizz and vibrate much more. and might need a bit more checking.
Personally, I actually like that.
Spaceframes racing cars with fizzing bodywork caused by solidly mounted engines is one of those odd things that I find really quite endearing.
If you've ever stood next to a silent hillclimb single seater when the DFV solidly mounted in the back is fired up, you'll know what I means.
It's very very business like.
kango
posted on 20/5/12 at 06:26 PM Reply With Quote
Thanks, So far it sounds like a GO for a silidly mounted engine. I have seen our Polo Cup car's engines are solidly mounted but would like to hear from other people
owelly
posted on 20/5/12 at 06:41 PM Reply With Quote
I've used polybushes to mount my engine so its not technically, solidly mounted but the chassis will flex before the engine moves but it takes away a some of the vibrations.
http://www.ppcmag.co.uk
eddie99
We run the bike engines solid in a rear Engined car, only thing have to be sure that the chassis is stiff enough, if it twists etc...More chance of blowing one up. Not sure how important this is in a car engined car but probably less important
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
kango
posted on 20/5/12 at 06:58 PM Reply With Quote
Only going to rev to 7500 not to 14K so should vibrate less??
Although car engines not usually balanced as well as a bike engine.
