Author: Subject: Bust Snap on Ratchet
Minicooper
posted on 2/6/12 at 03:51 PM Reply With Quote
Hello,
I have broken my 15" 1/2" drive ratchet taking off a mercedes wheelstud, the innards are knackered now, it is not worn at all, how do I get it fixed/replaced under the snap-on lifetime warranty?
I originally bought the ratchet with a load of other stuff about 20 years ago from a snap-on dealer in South Shields, I now live in Chandlers Ford, Eastleigh, I have looked on Google to see if there is a local snap-on dealer franchise that can deal with this on my behalf but not having much luck at the moment
posted on 2/6/12 at 03:56 PM Reply With Quote
Find a friendly local garage and ask if they have a Snap On dealer who will replace the innards. IIRC ratchets are only warranted for 5 years?
spiderman
posted on 2/6/12 at 04:02 PM Reply With Quote
Ratchets should only be used after breaking the initial bond between the stud and wheel otherwise they can fail. Use a breaker bar, (clue is in the name) first then use the ratchet to unwind the stud.
[Edited on 2/6/12 by spiderman]
Spider
big_wasa
posted on 2/6/12 at 04:04 PM Reply With Quote
Unless you have a rep your trading with I find the waranty is worthless. Undoing wheel nuts with a ratchet isnt fair use any way so again I doubt they would warant it.(yes I know every one does it instead of fetching the breaker bar) I would look for a rebuild kit.
And if you find one let me know as I have a 3/8 stubby that has needed doing for years
Minicooper
posted on 2/6/12 at 04:06 PM Reply With Quote
I know some tools like electrical meters/ mig welders have limited guarantees, but all hand tools have lifetime warranties, well that was I was told when I was deciding whether or not to purchase them, unless of course you abuse them
I don't even know if there is a service kit available for a ratchet 20 years old
big_wasa
posted on 2/6/12 at 04:12 PM Reply With Quote
Whats the model number ?
Minicooper
posted on 2/6/12 at 04:13 PM Reply With Quote
They used to make the same ratchet up to 24", so I expect it to be able to cope with a 12mm wheelstud, I would of used my snap-on breaker bar but I broke that years ago!
I haven't got a six foot piece of scaffolding bar on it, I shouldn't be able to break it with one armed pull as it where, but we will see.
Minicooper
posted on 2/6/12 at 04:14 PM Reply With Quote
S715
big_wasa
posted on 2/6/12 at 04:32 PM Reply With Quote
any friends state side that could post cheap ?
Only a tenner but the postage is daft. picture gives part number though.
Minicooper
posted on 2/6/12 at 04:44 PM Reply With Quote
For information I removed the wheelstuds with the mercedes toolkit supplied wrench, the freebie wrench supplied was only about 10" long but was able to remove the wheelstuds without incident
big_wasa
posted on 2/6/12 at 04:45 PM Reply With Quote
p!ss taking T@@ts 10 dollars or 30 quid
http://buy1.snapon.com/catalog/searchLN.asp?partno=RKRA711&searchTrnsfr=true&search_type=Part&store=uk
posted on 2/6/12 at 04:55 PM Reply With Quote
Do you mean wheel bolts? Studs are usually a press fit into the hub.
Minicooper
posted on 2/6/12 at 05:20 PM Reply With Quote
Yes that's what I mean, working on my mini done that!
Minicooper
posted on 2/6/12 at 05:25 PM Reply With Quote
Hopefully I won't have to buy one but it's nice to know they are available, where is the link for the uk option £30?
[Edited on 2/6/12 by Minicooper]
big_wasa
posted on 2/6/12 at 05:37 PM Reply With Quote
[Edited on 2/6/12 by big_wasa]
Minicooper
posted on 2/6/12 at 05:42 PM Reply With Quote
Even though that link says uk it comes up with the $10 option, how did you work out that is the right service kit?
big_wasa
posted on 2/6/12 at 06:32 PM Reply With Quote
I looked it up on there website.
http://buy1.snapon.com/catalog/objects/7800/RepairKits.pdf
big_wasa
posted on 2/6/12 at 06:35 PM Reply With Quote
It opens the uk option and in £ for me.
Go to there home page, choose uk option at the bottom of the page and search for item code.
jollygreengiant
posted on 2/6/12 at 06:59 PM Reply With Quote
My wife says if you ring 01536 413800 that will put you through to snap-on who will be able to advise you who your 'local' dealer is and possibly give you his mobile number for contact.
Why 'my wife says', well its because she works for Snap-On in their repairs department. But DON'T tell everyone.
blakep82
posted on 2/6/12 at 07:15 PM Reply With Quote
you can buy ratchet repair kits in halfords, while i wouldn't assume that ratchets are all the same inside, they don't seem to say they're only for certain types... they just say like '1/2" drive ratchet repair kit" or something. have a look, you might be in luck!
________________________
Minicooper
posted on 2/6/12 at 07:21 PM Reply With Quote
Thanks for the help
Steve126
posted on 9/6/12 at 11:36 AM Reply With Quote
I had a problem with a snap on ratchet and wasn't sure how to get it fixed without spending a load of money, but my Dad solved the problem when he saw a snap on van stop outside a garage. He spoke to the driver who asked what ratchet it was and where we live, he then ordered the necessary parts and told my Dad when he would next visit a local garage. A few days later he fixed it free of charge.
