Author: Subject: Damp
richard thomas
posted on 9/6/12 at 03:17 PM Reply With Quote
Damp
Hallo,
Just been crawling around under my downstairs floor looking for a central heating leak. Found it, but it has been leaking for some time now, and the solid ground below the floorboards is quite damp, wet in the area around the leak...
When I originally bought the house and did a considerable amount of work, I remember it was dry down there at the time.
So, how do I dry it all out? or will it dry itself now that the leak is cured?
Cheers, Rich.
mookaloid
posted on 9/6/12 at 03:27 PM Reply With Quote
If there are vents (air bricks) it should dry itself out.
Or can you get a dehumidifier in?
Chippy
posted on 9/6/12 at 04:39 PM Reply With Quote
No point worrying about it, if it's just on the sub floor it will dry out eventually. IMHO Ray
stevegough
posted on 9/6/12 at 05:45 PM Reply With Quote
Chippy's quite right, Rich. It'll dry out on its own - just cure the leak and worry not. (Just be glad you don't live in the Thornton area - under their floors / and their gardens is a permanent puddle)! That's why Its called Marsh Mill and 'Red Marsh industrial estate' - it all used to be a marsh.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
richard thomas
posted on 9/6/12 at 06:08 PM Reply With Quote
Nice one lads....I thought it might, but there is always an answer on here that backs things up
Cheers, Rich.
