Author: Subject: capri
binraker
posted on 4/9/04 at 03:54 PM Reply With Quote
capri
a friend has been offered a capri. are these any good as a donor and dose any one have an pic of the bits out of one.
what is it about me that makes me look like i know what im doing????
Mark Allanson
posted on 4/9/04 at 06:39 PM Reply With Quote
Engine, box, prop, rear axle, steering column, clocks, wiring loom, just about everything except the front suspension. I think the axle is better than the escort, they also usually come with useable wheels.
Mark Allanson
posted on 4/9/04 at 06:40 PM Reply With Quote
mangogrooveworkshop
posted on 4/9/04 at 10:58 PM Reply With Quote
Originally posted by Mark Allanson
Sorry, forgot the picture!!
bit off topic mark fuel pump looks a tad exposed. Just a humble observation.
pat
Mark Allanson
posted on 5/9/04 at 06:33 PM Reply With Quote
Its a bit deceptive, the pump is anout 1 1/2" above the stainless protection plate, well out of the way of any road damage, but a water shield is on the drawing board
robinbastd
posted on 5/9/04 at 09:52 PM Reply With Quote
" but a water shield is on the drawing board"
Are you expecting rain indoors?
http://smuttygifts.com/
Mark Allanson
posted on 5/9/04 at 09:55 PM Reply With Quote
yeh, OK, it will be finished soon!!
stu205
posted on 27/9/04 at 07:32 AM Reply With Quote
sounds like a dream!! im guessing you mean the mk2 version??
zilspeed
posted on 27/9/04 at 08:22 AM Reply With Quote
A Capri MK111 would have all of this as well seeing as it's just a MK11 with a bit of a facelift.
P.S. you could also use the front struts and modify them to accept a top adapter. A friend has this very setup on his hillclimb car.
stephen_gusterson
posted on 27/9/04 at 09:11 AM Reply With Quote
granada and sierra fuel pumps are in a really exposed position - the clamp that holds them in place gets a hard life, but the pump looked ok on my 13 year old donor. works fine on the car.
I built a alu box, put the pump in a tube in the box centre with the space between box and tube filled with expanding foam.
direct mounted pumps might set up an annoying vibration / noise thro the chassis.
atb
steve
zilspeed
posted on 27/9/04 at 10:08 AM Reply With Quote
You're not wrong there. Mine clatters away like a jackhammer.
